09-03-2017 01:59 PM - edited 03-21-2019 10:54 AM
I purchased 2 RV340 and performed latest firmware update, bur still getting subnet range error when setting up PPTP VPN. Is there a solution to this issue?
09-05-2017 04:08 AM
Can you please confirm what type of IP range you are trying to enter for the PPTP VPN?
Are you using the same range which you already have for VLAN 1 or another range already defined?
As this is a brand new device feel free to give us a call so an engineer can open a support ticket and assist you in the configuration.
Kris
10-30-2017 02:26 PM - edited 10-30-2017 02:28 PM
I'm getting the same type of error when I attempt to setup the PPTP Server as well. Purchased this Router (RV340) to replace my RV042G,
VLAN1: 192.168.169.254/24
PPTP IP Range: 192.168.169.200-204
Firmware: v1.0.01.17
03-23-2018 05:38 PM
I have same issue. Any updates on this?
10-26-2017 09:30 AM
I get this message too regarding L2TP. Have you been able to fix this issue?
