RV340 - TLS 1.0
Hello guys,
I did not find a way to disable TLS 1.0 for https in the RV340 settings.
I would like to disable TLS 1.0 on port 443 due to security holes.
makamine
conseguiu resolver Cezar?
Estou com esse problema tb
thebrain
this thread hasn't been answered in 5 years and there still isn't any TLS configuration option in the RV340 so it's very clear that Cisco doesn't care.
To fix this for my network, I installed openvpn on an internal server and used port forwarding on the RV340 to connect the VPN ports. The latest network scan of our public IP came back with no TLS vulnerabilities.   OpenVPN is technically better than the VPN offered by the RV340 as it allows for MFA as well as PAM/LDAP/SAML.
If you need to fix this on the RV340, you will have to pay for a support account just to find out if a fix it possible.  Otherwise, I suggest disabling SSL on the RV340 and using a 3rd party VPN solution if possible.
 @thebrain  Ref https://www.cisco.com/c/en/us/products/collateral/routers/small-business-rv-series-routers/small-business-rv340-rv345-series-eol.html
End of Vulnerability/Security Support:
HW
The last date that Cisco Engineering may release a planned maintenance release or scheduled software remedy for a security vulnerability issue.
October 28, 2022
 M,
