I want to configure a vpn connection with the pptp protocol. I want to use the windows 10 native client to connect. Once configured, it works fine.
The problem is that I do not want to use the remote server's gateway. I want to use the gateway of the local internet connection. For this, in the "Advanced TCP / IP configuration" of the vpn connection in windows, uncheck the option "Use default gateway of the remote network". In this way, I keep surfing directly to the internet (faster) but I can connect with the IPs of the office through the tune VPN.
This configuration has worked well with my old Cisco RV180, but it does not work with the RV340. I understand that it must be that different subnets are used.
Anyone knows how to solve this?
