rv340w the admin panel does not open
braben
I live in Russia, the admin panel has stopped working for everyone, right? I enter the correct username and password, then it just spins all the time and that's it, it doesn't write any errors
8 Replies 8
marce1000
      - Try other browser(s) to check if the problem is persistent
 M.
braben
I've already tried it
 - Probably the only thing you can do is factory reset and configure again or restore configuration.
 M.
braben
most likely it won't help
 - Contact Cisco : https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
 M.
braben
here is the official support response
Your account has been deactivated due to Cisco’s ceasing of business in Russia and Belarus. As a result, we are stopping your Cisco Service effective immediately, including technical support, service replacement hardware (RMAs), software licenses and downloads, and any additional technical or other services.
What should I do now? I need to go to the admin panel anyway
braben
the admin panel is still not working
braben
automatic update firmware via usb will help or not?
