01-11-2021 08:09 AM
When I purchased this product a few years ago it was mandatory that you applied firmware updates in sequential order. Has this issue been solved? Can I update directly from 1.0.01.18 to 1.0.03.20
01-12-2021 12:12 AM
- These type of devices usually don't have that kind of dependencies, which this document seems to confirm :
M.
01-12-2021 01:01 AM
Hello, longbeard,
Yes, you can. With the RV series routers as marce1000 said there is no such a requirement so you can proceed with direct upgrade to the latest one.
Martin
