RV34X - disable SPI
SolidSnakeSK
Can anyone from Cisco clarify how to disable the SPI on the new RV34X models? It´s causing a lot of problems in our environment, on the old RV32X models, there was a checkbox, on the newer ones there isnt.
ktonev
My name is Kristian and I am one of the engineers from the Small Business team.
Unfortunately, the RV34X routers do not support the functionality to disable SPI individually. This is a device limitation and in order to disable SPI you will need to disable the whole Firewall functionality.
What I can suggest is to contact our support center to explore whether it is possible to open a feature request for this particular issue.
Hope that helps,
Kris
Hello, even with FW disabled, SPI stays on and the router keeps inspecting the packets, which causes communication problem with various web services our clients use.
I hope this helps you or the others who have similar issue. I disabled the SPI by downloading the XML file, and change the SPI value on the file, from "true" to "false". Then I save the file and uploaded it to the router.
