07-17-2011 05:47 AM
I have an unstable connection, 2-3 x per day, no more connection to the router, required to cut the power supply 12 volts and lost my ip (dynamic), - the router is new.-
- no problem with a simple WRT54G in place.
- the problem also occurs whenever any PC connected to the RV4000 am not for several hours (absolutely no rj45 connected)
Is there a solution or is this a bug
thanks
Lire phonétiquement
07-25-2011 04:26 AM
Have you tried resetting the router back to factory defaults? If not, give this a try and see if you have better results.
If your problem persists I would ask that you give us a call at our Cisco Small Business Support Center. The number in the US is 1-866-606-1866. This way we can create a case for you and help troubleshoot the problem.
THANKS
Rick Roe
07-25-2011 06:26 AM
I just did a reset to factory default, I did well for a reset button on the back of dvs4000 I do not know if the result is the same, and in this case I have not seen for improvement
I'll let you know after 24 hours of operation
best regards
André ON4HU
07-26-2011 12:12 AM
Essayez avec cette orthographe : après un reset avec le bouton à l'arrière du RVS4000 aucun changement encore un plantage total cette nuit. je rectifie les pages
Saisissez du texte, l'adresse d'un site Web ou importez un document à traduire.
Lire phonétiquement
07-26-2011 12:13 AM
after a reset with the button has the back of the RVS4000 no change
even a total crash last night.
I corrected the pages, I do not know if this influences the crash but my page "portrange Forwarding" contains some lines of "Single Range Forwarding" for lack of space *
