RVL200 Port Address Translation
mikehein1
Does the RVL200 offer Port Address Translation and it so where do I find the feature in the web interface. So far I have only found Port Forwarding and Port Triggering. The RVL200 has got the latest firmware installed (1.1.12.1).
Thankyou,
Robin Horn
Te-Kai Liu
Level 7
Level 7
The port address translation rule can be configured at Setup>UPnP page. You would have to add a Service that specifies the External port and Internal port. Note that the UPnP checkbox does not need to be checked. (The feature is known as Asymmetric forwarding, as opposed to the regular port forwarding.)
Damn EXCELLENT! I had been ripping my hair out trying to figure how to do that. Every article I read said the RVL supports the feature. I would have NEVER guessed to look under UPnP menu
