ā11-17-2009 08:27 AM
hello
I just want to know if its possible to use static dns (those of opendns) when my internet provider connect me through dynamic IP?
i am using the last firmware 1.3.0.5
thank you for your help ?
bolbix
ā11-17-2009 08:34 AM
With this router model, there is not the option to use custom dns on the wan if your getting your ip address dynamically. In order to implement the static dns you would need to implement a static ip address on this router. However any of the rv042, rv082 and rv016 routers will allow that function. Hopefully this helps you out Jerbol.
ā11-17-2009 08:37 AM
it's a pity !
thank you anyway for your so quick answer !
ā11-17-2009 09:24 AM
Static/Custom DNS server can be specified in the Setup>LAN page. If the DHCP Server is enabled, the DHCP clients will get that info and use it for DNS resolution.
ā11-17-2009 11:56 AM
absolutely but it's not a problem on the LAN but rather on internet. Because the router knows every address it assigns on my LAN but it needs informations for corresponding name and ip over internet: the reason to be of the DNS.
