01-12-2012 09:14 AM
Hello all,
I've been trying to disect this problem for a few months to no avail. The router allows me to connect to outside FTP only when IPS is enabled. The moment I disable the IPS functoin, the connection hangs and does not connect to a server. Reason I'd like to keep IPS disabled it is because it's eating up half of bandwith when enabled. I did the port forwarding, triggering, ACL, you name it. I'm just stuck at this point.
Any ideas? Suggestions? Thank you in advance.
RVS4000
Firmware Version: V1.3.2.0
01-18-2012 08:02 AM
or maybe you guys have detailed information of what changes when IPS is enabled, which protocols/functios are implimented?
02-08-2012 06:26 AM
bump.... love this tech support...it's like hitting your head against a wall.
Who can recommend other SMB with VPN routers? Something very stable... other brands?
Thank you.
