Bookmark
Subscribe
1172
RVS4000 problems
Ben__1642
Hello
I have recently purchased a RVS4000 VPN Router and I have a slight problem I wish an expert to help me with.
At home I have a 100Mbps internet connection which gets a result of around 80-98Mbps on the speedtest.net . However, when I connect the RVS4000 to my network I can only achieve 20Mbps. I am using Cat 6 cabling for everything with Gigabit ports. The QoS / bandwidth settings are disabled.
Any ideas what could be causing the slow down?
Chris D
doug_counsil
Disable IPS and re-test.
Hi Doug
I’ve tried it and it works perfectly!!!
Cheers
CD
IPS is resource (CPU) intensive.  We used it for years with a WRVS4400N v2 and now with an SA540.  Even with the more expensive SA540 we our WAN throughput is limited to ~24Mbps.  We pay for 30Mbps down and 5 Mbps up so we aren't losing much.
