Rvs4000
automatejackson
Im trying to create a .txt config file from the rvs4000 as i use them regularly in my job and would like an easy way to make changes to the setup. I have saved the .cfg file from the router and changed the extension to .txt but when i try to open it, all the info is encrypted. is there anyway around this?
Ryan
Te-Kai Liu
Level 7
Level 7
This is not possible with the current firmware.
