RVS4000
jswxyz2011
Looking to buy the RVS400
Does it support SSL VPN? As I would like to have secure web access without installing other software.
James
jasbryan
Level 6
Level 6
James,
No the RVS4000 only supports IPsec tunneling and Qvpn. I would invest in the NEW RV220W , which gives you the ablitly of PPTP ,SSL, and IPsec.
SSL models
RVL200 - SSL/IPsec-Qvpn (not support on 64 bit)
http://www.cisco.com/en/US/prod/collateral/routers/ps9923/ps9927/data_sheet_c78-502734.html
RV220W - SSL/PPTP/IPsec - Qvpn  (more robust)
http://www.cisco.com/en/US/prod/collateral/routers/ps9923/ps11025/data_sheet_c78-630461.html
http://www.cisco.com/en/US/products/ps9932/prod_models_comparison.html
SA520 - SSL/IPsec/Cisco Vpn (Cisco vpn paid, or if you have 3 year support contract)
SA520W - (Same)
SA540 - (Same)
Jason Bryant
Cisco Support Engineer
The RV220W looks like a great unit. Will definetly get one. A little more than I was looking to spend but the specs definetly make it worth it.
Any idea when it will be availible in the UK as all the websites I look at say it's out of stock.
