SA520 Quick VPN connection
reparator
Hello
After 1 week setting and testing we are succesfully login to SA520 using QuickVPN client,but we meet another problems  and questions.
We create different IPsec users and try connect remotely.
Once any user can connect to SA520 succesfully,and we try login from another computer with different or same name in "Status","Quick VPN connection status" I can see both user online,but second never connect to SA520(remote  not responding  do you want to wait????).
So it seems only one paralel connection possible.
We are using XP,latest FW 2.1.18 and latest Qvpn client 1.4.1.2
1.Is  there any tips or settings which can cure this problem  ???
2.When we adding newI PSEC user,must add router LAN IP address.
It seem to add valid IP address,because Qvpn not working,when adding empty IP address.
3.How can  I make or download certificate for this router,because always said "Certificate not correct"
Thank you
Tibor Kovacs
0 Replies 0
