srp521 port forward based on source ip
Sage Major
I have a customer with a Sonic wall that I want to replace with a 521.
He currently has port forwaring setup so that only 3 ip addresses can access the port forward.  Everyone else is dropped.  Is there a way to do something similar?
I can make it work for a single one via the DMZ tab with a source ip address. but there is not a way I can find to add the allow for the other two remote connections.
Is it not on this router or am I looking in the right place
Andrew Hickman
Hi Sage,
You can't specifically limit a port forwarding rule to a given source address.
You could try creating a general port forward though, but then add a couple of Access Control rules (Advanced Firewall Settings) to explicitly permit traffic from your trusted sources / ports and deny all otheres.
Andy
