[SRP527w] Use Ethernet Port 4 as a WAN Port ???
ggarnierseml
English:
Hi everybody,
I just can't figure out how to use the ethernet port 4 as a WAN port.
I think it's possible since it's labelled LAN/WAN on the back of the device... If someone succeed, please let me know how!
Thank you for your help,
Gaultier.
Français:
Bonjour à tous,
Je n'arrive pas à configurer le port ethernet 4 en monde WAN.
Il me semble que c'est possible puisque le port s'appelle LAN/WAN sur l'appareil... Si quelqu'un a réussi, merci de m'expliquer comment!
Merci d'avance de votre aide,
Gaultier.
2 Accepted Solutions
Andrew Hickman
Hi Gauliter,
Please use the Administration > Switch Setting menu.  Set the DSL Interface option to Disable to use LAN Port 4 instead of the ADSL interface.
Note, this setting will factory reset the router and completely disable that ADSL interface.
I hope this helps,
Andy
The newly launched SRP547 has both ADSL and GigE WAN interfaces....
Andrew Hickman
Hi Gauliter,
I hope this helps,
Andy
Thank you very much Andrew, I think I'm not the only one it helps!
Too bad it's not possible to use LAN 4 as a backup WAN when ADSL fails...
Hope it will be possible in a future firmware release.
Gaultier.
