SRP541w DNS Proxy issue
parallaxtech
I'm running FW 1.02.01 (23) and I'm having problems with the DNS proxy.  I have DNS Proxy enabled for my DHCP server on the router and I have my dns server programmed into the global dns location.  I cannot ping any DNS names for my IPSEC VPN tunnel.
Adam De Lay
Andrew Hickman
Hi Adam,
Could I first recommend that you upgrade to version 1.2.4.  This is available for free download, just go to www.cisco.com/go/srp500 and look for the link on the right.
If you are still seeing the issue after upgrade, could you please grab the device status file (Administration > Remote Support) and send to me please. [Don't post it here]
Andy
Andy,
I cannot upgrade to the latest version due to problems it has with the IPSEC tunnels.  This seems to be the latest stable version for the tunnels but it breaks the DNS proxy.  If I disable the proxy and set the DNS server to the same that it was for the DNS proxy, it works fine, but thats only a temporary solution because I need to have multiple DNS servers.
Adam
