04-25-2023 10:26 AM - edited 04-25-2023 01:31 PM
I went to log into the router today to open a port for vendor support, but the web login is no longer working. It loads the login screen where I can enter the username/password but it seems like nothing happens when I try to login.
Everything is working on the local network the way it always has been. I have unplugged it and restarted it all to no avail. Has anyone encountered this before or have any direction on how to get by this? I have tried multiple computers and web browsers as well, still the issue persists.
I've attached a screenshot of the web interface and how it looks when I try to login.
Thanks in advance.
04-25-2023 11:19 PM
- Try to fetch the web login page with https://eternallybored.org/misc/wget/1.21.3/32/wget.exe , post result here ,
M.
04-26-2023 10:23 AM
04-26-2023 10:50 PM
- No obvious problems seen with that ; use google Chrome and press F12 , then try the web login , check the output in the development pane ,
M.
