09-13-2015 07:08 PM
Dear experts - Currently, I fail to hook up Huawei - E3276 by using RV325 (I still searching solution). Would you share your model which is hook up with RV325 successfully? Your share and reply will be appreciated. Thank you.
Tommy
Solved! Go to Solution.
09-14-2015 01:54 PM
Below is the link to the support dongles:
http://sbkb.cisco.com/CiscoSB/GetArticle.aspx?docid=12f7ca151d2140e3902db3565e5b494d_Dongle_Support_on_the_RV320_and_RV325.xml&pid=2&converted=0
You can get device added to the list by contacting the support Center. 866.606.1866.
Best Regards,
Mike
09-14-2015 01:54 PM
Best Regards,
Mike
