01-17-2016 07:44 PM
Is it possible to setup a VPN connection between a 881-W Cisco router and remote end WRVS4400N? If so could I get some help with the 881 config. This is the piece that I am struggling with.
01-18-2016 01:04 AM
Try using my config wizard. Select the Cisco 871. The config is very similar.
http://www.ifm.net.nz/cookbooks/800-isr-wizard.html
Log in to Community
