VPN IPSEC SITE to SITE rv042 and rv160
badmotorfinger
I have 7 vpn tunnels created between rv042 and different cisco rv110, rv120 and rv130.
I need to create a new connection and for this I purchased the replacement for the rv130 which I was informed was the Rv160, the problem is that I can't get it to connect to the VPN. The routers seen each other but the connection is not achieved.
The settings are identical in both, I don't know what could be happening. I am attaching configuration photos, I don't know if I'm missing something.
Thank you
marce1000
 - Check logs on all involved devices or configure a syslog server (better) ,
 M.
badmotorfinger
I was able to make it work after racking my head.
It turns out that in "Remote Group Setup" if in Remote Identifier Type I select Remote FQDN and in Remote Identifier I put my dynds address, the VPN does not connect, on the other hand if I leave Remote FQDN and put the IP of the remote router, yes.
I understand that it is a firmware bug since when selecting "Remote FQDN" the "remote identifier" field should appear greyed out and take the IP of the fqdn defined above in "Remote Endpoint". Exactly as how the Local Group Setup works.
