Web SSL VPN SA540
gerald.freiler
Got Problem when try to connect from an fresh installed windows 7 x64 PC with internet Explorer 8.
The Error Message:
               Cisco-SSLVPN-Tunnel Install Failed: Error in Removing existing Cisco-SSLVPN-Tunnel Adapter!
Internet Explorer is startet "As Administrator"
The install routine was never running on this PC, so what existing SSL Adapter he want do remove?
The Router has the latest FW installed.
Gerald
gerald.freiler
No one got the same problem?
Still looking for an solution.
Gerald
Gerald,
I seen that your using the IE8 browser to connect to the router.  Have you tried the 64 bit IE8 when connecting to the router?
David,
yes I have used the 64 bit browser of win7. Also tried it with IE9 x64.
