This question is about a CISCO1941/K9 router, Version 15.0(1r)M15.
When I type
reload in 4
it asks me
System configuration has been modified. Save? [yes/no]:
% Please answer 'yes' or 'no'.
even though
show archive config differences system:running-config nvram:startup
gives
!Contextual Config Diffs:
!No changes were found
and
show running
gives
Current configuration : 5031 bytes
! No configuration change since last restart
My question is: how can I determine WHAT system configuration has been modified?
As far as I know, the only thing changed would be the terminal length which I occasionally toggle for use with session logging with Putty, i.e.
terminal length 0.
I would really appreciate some guidance here. This router has been in production for months and I don't want to break anything (obviously). I need to make one change to the access-list config and wanted to protect myself by telling it to reload in 4, and then I would most likely reload cancel in about 1 minute. But now I am worried about this save yes/no question.
Thank you.
