06-15-2022 12:39 AM
RV325 with FW RV32X_v1.5.1.13, Please help me to solve this issue.
06-15-2022 01:45 AM
- Depends , what is connected to it ? And what is the network capacity of those devices ?
M.
06-21-2022 04:21 PM
My name is Nikola and I'm a SBD team member.
You may try with any of these actions:
Disable flow control v LAN-Port Settings on WAN interface.
Disable PnP in System Configuration.
Disable Policy Based Routing in Multi-WAN.
Disable Network Service Detection.
07-05-2022 02:10 AM
Speed totally depends on the opposite device what speed is set there and what that device auto-negotiate.
if you are not sure about that then check with another device that supports 1G and connect with the router you will get an auto-negotiate 1G by default.
As your snap shows some devices are connected on 1G.
