Wifi to wifi ping (visible)
sao00000111
Hello, please help me. I have a Cisco router RV130W. When I connect my laptop (localhost) on a LAN cable and a second computer (client) connected to WIFI, everything works OK. But when I connect my laptop (localhost) to WIFI and a computer (client) to WIFI, it does not work. Also ping wifi to wifi does not work and for that does not work wifi printer if I am not connected directly on LAN cable. What do I set up on the router for correctlly working on wifi and wifi connection?
Jorge Obregon
I hope you are doing well. Based on the information you are giving us I would advise you first to do the firmware upgrade in case the device is not under the latest firmware version 1.0.3.16, here you have the link to download that version.
https://software.cisco.com/download/release.html?mdfid=285026142&softwareid=282465789&release=1.0.1.3
if the device is under that version already. I would advise you to check and compare both IP configurations (localhost and client) to make sure you are getting the same IP and default gateway.
Also if the password is already save on both computers please try forget password and reenter the credentials.
I hope this helps you.
Hi, Thanks for responding. I have a problem after a long search and testing by setting it causes successfully solvedNobody knew me in that order. The problem was
- Enable wireless isolation within the SSID
To uncheck this setting and wifi printer is visible on a computer connected to wifi. All computers connected to wifi ping responding.
Sincerely
Hi,  that makes a lot of sense. I am glad you have resolved the issue
