12-22-2010 06:25 PM
Hi!
I'm using two WRV210 Linksys Cisco Routers to create a tunnel between two places with a pppoe adsl internet connection.
I made several tests with new 2.xxx and old 1.7xx firmware, and nothing changes.
Try to reset to factory defaults, and nothing changes.
I have two problems:
1) The router crashes after a time working, usualy around 24 hours, sometimes more, sometimes less. The lights still flashing, but nothing happens, no VPN traffic and no ping response from the router, and of course, no internet access. I could see just that the router works a bit hot, but, I think that is normal.
2) The VPN IPSEC was configured, and both configurations are identical. All value are the same, I am using the dyndns service. So, the VPN quickly connects and I can ping and access remote computers. Windows Folders, VNC, IT'S REALLY WORKS FULL. WORKS REALLY FINE. PERFECT.
BUT, when the router crashes, as I've told on problem 01, after remove the power cord and insert ir again, the VPN don't reconnect.
On log's, I could see that it's say that has no preshared key.
062 [Wed 22:48:10] "TunnelA" #37: Can't authenticate: no preshared key found for `201.95.224.20' and `201.43.135.139'. Attribute OAKLEY_AUTHENTICATION_METHOD
063 [Wed 22:48:10] "TunnelA" #37: no acceptable Oakley Transform
064 [Wed 22:48:10] "TunnelA" #37: sending notification NO_PROPOSAL_CHOSEN to 201.43.135.139:500
But, please, pay attention, it worked before. Nothing changes, nothing, the router just restarts. No configuration was lost, (I checked the VPN IPSEC TAB), but says that have no preshared key, BUT THE KEY STILL THERE.
The unique way to restablish the connection is go on the VPN IPSEC TAB, and change symetrical any configuration, as change MAIN MODE to AGGRESSIVE on both routers.
So, now are as MAIN. Tomorow probably it will crash, so, I will have to restart both routers, and change to AGGRESSIVE. So, when it happens again, i will have to back to MAIN.
If I change the preshared key, on both routers, It will work, too.
Anyone can help-me?
I really need a ultra stable VPN tunnel, and I think that CISCO could do it for me, but I think that I was wrong.
David
05-21-2011 03:22 AM
I had these routers bought originally with the 1.1.17 firmware, it had these problems, so I flashed it with the latest firmware hoping it will solve the problem but it didn't. so i'm pretty sure both the old and new firmware had the same problem....
I have 2 WAN link sitting idle, waiting for the WRV210 fix.... well.. I've waited at least for 10 months.
10-04-2011 07:02 AM
I too have just purchased 2 of these devices and am having the lock-up issue. I have upgraded to the latest firmware and still no change. Any update on this? From anyone?
10-04-2011 07:11 AM
There is no changes on this case as you see. Don't waste you time with this product. I changed to Dlink and everything works perfect!
10-10-2011 03:52 AM
Were you able to contact the Cisco Small Business Support Center to open up a service request for you on this problem?
The number to call is 1-866-606-1866.
THANKS
Rick Roe
10-10-2011 04:22 AM
