WRVS4400N and SPI
josewhit
On the latest versions of the WRVS4400N Firmware, is it still using SPI (Stateful Packet Inspection) and is there a way to turn it off??
David Hornstein
Level 7
Level 7
Hi Joseph,
Since the WRVS4400N firewall  uses stateful packet inspection there is an option, if you want,  to turn off the firewall. What issue is it causing ?
i copied the following helptext from my WRVS4400N.
Firewall
SPI (Stateful Packet Inspection) Firewall, when enabled this feature, the router will perform deep packet inspection on all the traffic going through this router and drop those packets which does not follow the pre-defined protocol behavior. Default is Enable.
regards dave
