Hi.
I have a WRVS4400N router I'd like to use in AP only mode. I'd like to have a main/corporate WIFI, which should be plugged to the LAN, and then a Guest Wifi which I'll connect to the firewall.
Since the switch I have in house are unmanaged, is there a way to do this without VLAN tagging?
What I wish to accomplish is to assign corporate wifi to LAN port 1 of the WRVS and the guest to the LAN port 4. Is it possible?
thanks
