01-30-2014 12:41 PM
Hi folks,
I have a problem with seting up working tunnel between WRVS4400N and my mac. As client software I am using IPSecuritas 4rc. I have succesfully created tunnel, I can ping any host but cannot access it from brouser.
Here is screen shot from WRVS4400N IPSec section
IPSecuritas config:
It doesn't work.
I will appreciate for any advise or idea. Thank you.
01-30-2014 03:41 PM
Serge,
I'm a little confused about what is/is not working.
"I can ping any host but cannot access it from brouser."
If you can ping any host, then the tunnel is successful. You cannot reach the web browser of the router? Can you access shares on the computers?
- Marty
01-31-2014 03:31 PM
This is how it is looks like:
MBP2:~ user$ traceroute 192.168.1.13
traceroute to 192.168.1.13 (192.168.1.13), 64 hops max, 52 byte packets
1 * * *
2 * *^C
MBP2:~ user$ ping 192.168.1.13
PING 192.168.1.13 (192.168.1.13): 56 data bytes
Request timeout for icmp_seq 0
Request timeout for icmp_seq 4
^C
--- 192.168.1.13 ping statistics ---
6 packets transmitted, 0 packets received, 100.0% packet loss
MBP2:~ user$ ping 192.168.1.14
PING 192.168.1.14 (192.168.1.14): 56 data bytes
Request timeout for icmp_seq 1
^C
--- 192.168.1.14 ping statistics ---
3 packets transmitted, 0 packets received, 100.0% packet loss
MBP2:~user$ ping 192.168.1.1
PING 192.168.1.1 (192.168.1.1): 56 data bytes
64 bytes from 192.168.1.1: icmp_seq=0 ttl=64 time=148.457 ms
64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=149.230 ms
^C
--- 192.168.1.1 ping statistics ---
4 packets transmitted, 3 packets received, 25.0% packet loss
round-trip min/avg/max/stddev = 148.457/149.375/150.437/0.815 ms
MBP2:~ user$ nmap -sP 192.168.1.0/27
Starting Nmap 6.40-2 ( http://nmap.org ) at 2014-01-030 13:14 EST
Nmap scan report for 192.168.1.1
Host is up (0.15s latency).
Nmap scan report for 192.168.1.2
Host is up (0.18s latency).
Nmap scan report for 192.168.1.10
Host is up (0.17s latency).
Nmap scan report for 192.168.1.11
Nmap scan report for 192.168.1.12
Host is up (0.19s latency).
Nmap scan report for 192.168.1.13
Host is up (0.16s latency).
Nmap done: 32 IP addresses (6 hosts up) scanned in 3.92 seconds
And from Firefox:
The connection has timed out
The server at 192.168.1.1 is taking too long to respond.
Routing table "other site of the tunnel"
Routing Table Entry List | |||
Destination LAN IP | Subnet Mask | Gateway | Interface |
192.168.1.0 | 255.255.255.224 | 0.0.0.0 | LAN |
76.15.128.0 | 255.255.252.0 | 0.0.0.0 | WAN |
0.0.0.0 | 0.0.0.0 | 76.15.128.1 | WAN |
My site:
MBP2:~ user$ netstat -r
Routing tables
Internet:
Destination Gateway Flags Refs Use Netif Expire
default 172.16.254.254 UGSc 13 19 en1
127 localhost UCS 0 0 lo0
localhost localhost UH 3 4629 lo0
169.254 link#5 UCS 0 0 en1
172.16.254.240/28 link#5 UCS 1 0 en1
172.16.254.241 localhost UHS 0 3 lo0
172.16.254.254 4c:60:de:e7:ad:f3 UHLWIir 14 409 en1 1159
02-05-2014 01:11 PM
Serge,
You can ping the router and nothing else?
- Marty
