WRVS4400n
Diesel3737
Recently i purchased and setup a WRVS4400n for vpn access.  I am able to connect from my home PC (XP) using the quickvpn client.
2 Questions.
1.  is there a quickvpn client for MAC and if not, any ideas what my options might be?
2.  is there a way to connect using vpn without the quickvpn client (I do this with 2 other routers using pptp - RV042 and RV016).
Thanks you
19 Replies 19
Just to note ... I can use the gtkint37.gotdns.com when connecting via QuickVPN
if you are still not able to connect export the IPSecuritas settings and send them to me via IM. Please also post when you give this another go.
How can I send you the config file?
Here is the log file.
From the looks of the screenshot, we are not resolving the name or the router is not configured correctly. Take a look at the document again and try again. You can send the config files via IM here in the forums, just click on my avatar and send an email.
After you take a look at the router configuration let me know and we will go from there.
