2821 card command problem
hernanseijas
Visitor
I have installed am ATM module in a 2821 router, but I have no chance to put the command 'mode atm aim 1'
murotuer(config)#controller E1 0/3/0
myrouter(config-controller)#mode ?
  cas  Configure CAS (Channel Associated Signal) mode
  ccs  Configure CCS (Common Channel Signal) mode
myrouter#sh diag
AIM Module in slot: 1
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-27059-01
        Board Revision           : A0
WIC Slot 3:
        E1 (2 port) Multi-Flex Trunk WAN daughter card
        Hardware revision 1.0           Board revision A0
        Serial number     36554718      Part number    800-04479-05
        Version Identifier     V02      FRU Part Number     VWIC-2MFT-E1
IOS: flash:c2800nm-advipservicesk9-mz.124-24.T4.bin
I have tried in both ATM ports but nothing changed.
Any idea why I dont' have the mode ATM command?
Regards and thanks
Sorry that was bad use of copy & paste by me.
I should have pasted this :-
NAME: "Virtual Private Network (VPN) Module on Slot 1", DESCR: "Encryption AIM Element"
PID: AIM-VPN/SSL-2     , VID: V01, SN: FO
This is for VPNs and SSL
As I said this is the wrong type of AIM for ATM support
You need the AIM-ATM variant
Alex
Regards, Alex. Please rate useful posts.
5 Replies 5
acampbell
I think you may have the wrong kind of AIM card
Can you post show inven
Alex
myrouter#sh inv
NAME: "2821 chassis", DESCR: "2821 chassis"
PID: CISCO2821         , VID: V03 , SN: FTXxxx
NAME: "2nd generation two port FXS voice interface daughtercard on Slot 0 SubSlot 0", DESCR: "2nd generation two port FXS voice interface daughtercard"
PID: VIC2-2FXS         , VID: V01 , SN: FOCxxx
NAME: "2nd generation two port FXS voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "2nd generation two port FXS voice interface daughtercard"
NAME: "2nd generation two port FXS voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "2nd generation two port FXS voice interface daughtercard"
PID: VIC2-2FXS=        , VID: V  , SN: FOCxxx
NAME: "Two port E1 voice interface daughtercard on Slot 0 SubSlot 3", DESCR: "Two port E1 voice interface daughtercard"
PID: VWIC-2MFT-E1      , VID: V02, SN: xx
NAME: "PVDMII DSP SIMM with Two DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with Two DSPs"
PID: PVDM2-32          , VID: V01 , SN: FOCx
NAME: "8-port Analog Modem Card Version 2 on Slot 1", DESCR: "8-port Analog Modem Card Version 2"
PID:                   , VID: 1.0, SN: F
This is your issue.
This is NOT for ATM support.
You need
AIM-ATM variant
Alex
Sorry, but I don't understand 'NAME: "8-port Analog Modem Card Version 2 on Slot 1", DESCR: "8-port Analog Modem Card Version' is for dial up access.
I need to configure the ATM for the VWIC-2MFT-E1 card.
Regards and thanks
Alex
