ASR-920 vs HTTPS communication
Calderano
Visitor
Hello every one.
I have a part of my network using only ASR-920´s establishing connection over OSPF and BGP. All kind of accsess works (SSH, Telnet, HTTP), but in these days, I´ve needed to integrate a new device with management that works only over HTTPS, and not worked.
I ran the wireshark at the same network as my notebook in one ASR trying to reach the SW SEL-2730M connected at the other ASR, trying to reach https site of mamagement. The results are, in part, below
erro.jpgAn information importat: THERE IS NO ACL ON ANY OF THE ROUTER ASR-920
I´ll appreciate any support / help
B. Calderano
8 Replies 8
Ip http secure-server <<- are you add this?
@MHM Cisco World  thanks for your reply
in both box:
no ip http server
no ip http secure-server
Can you more elaborate
You need to access https of router or you want to pass https through router?
Of course... I need to access equipment connected to the ASR-920 router... the SE SEL2730 is connected to the ASR, in the same way as a SIEMENS RX1500 router... both with HTTPS access only...
I used two models to find out if the problem could be with the end equipment.
Duplicate tcp meaning some tcp is drop or there is asymmetric routing.
Https is tcp in base so we need to make traffic symmetric as we could.
MHM
In my scenario, I only have one ASR connected to the other by BGP + OSPF... and the equipment connected to one of these. I believe it is unlikely that we will have asymmetry in this case.
Ok
Show ip nat statistics
Check if out-to-in count is high or not.
dear @MHM Cisco World  in my boxes i don´t have these commands...
