Automatic failover EIGRP to BGP
protocol_1984
Community Member
HI,
Our branch office is connected to head office via 2 links from 2 different service provider. Traffic is routed through BGP via 1st service provider and traffic is routed through EIGRP (Tunnel) through 2nd service provider. 1st link is of 512 kb and second link is of 1 mb. the priority route should be thro 2 nd provider.
By default the routes are passing through the 1st provider as we route through BGP. Currently we remove BGP routes and forwarding the traffic to 2nd provider. Whenever 2nd link goes down we manually shift the traffic by adding routes in the BGP.
How to make it as dynamic failover and give priority to 2nd service provider of 1 mb and running EIGRP.
Scenario:
Config:
Router A:
interface GigabitEthernet0/1
ip address 172.x.x.246 255.255.255.252
router eigrp 100
redistribute static
redistribute bgp 65215 metric 100 1 255 1 1500
network 172.16.0.0 0.0.1.255
no auto-summary
router bgp 65215
no synchronization
bgp log-neighbor-changes
neighbor 172.x.x.245
redistribute eigrp 100
no auto-summary
Router B:
interface Tunnel200
ip address 172.16.251.1 255.255.255.252
tunnel source 87.x.x.154
tunnel destination 87.x.x.234
ip address 87.x.x.154 255.255.255.252
duplex auto
speed auto
router eigrp 100
network 172.16.251.0 0.0.0.3
Branch Router:
interface Tunnel200
ip address 172.16.251.2 255.255.255.252
tunnel source 87.x.x.234
tunnel destination 87.x.x.154
interface FastEthernet0/2/0
ip address 87.x.x.234 255.255.255.252
router eigrp 100
no auto-summary
ip route 87.x.x.0 255.255.0.0 87.x.x.233
9 Replies 9
milan.kulik
Level 11
Level 11
it's not clear how the routing on your branch router is done:
Is it running BGP to the first provider and EIGRP to the second?
You could run BGP through the Tunnel to router B then and make your route preferences tuned as you need possibly?
HTH,
Milan
Hi Milan,
Branch office routing is done by BGP through first service provider. I removed the BGP config as to make the traffic to flow thro EIGPR. The below is the actual config.
Branch Router:
interface Tunnel200
router eigrp 100
no auto-summary
router bgp 65215
no synchronization
network 172.16.5.X x.x.x.127
neighbor 192.168.131.57 remote-as 29684
no auto-summary
so wouldn;t it be possible to advertise to the Provider 2 via EIGRP only prefixes necessary to establish the tunnel and then run BGP between your HQ Router B and the branch router through the tunnel?
The configuring Local Preference correct way on both sites you could prefer the path through the tunnel, i.e, provider 2.
HTH,
Milan.
Can u give a sample config like where to tweak the settings. I have to do this in the live environment...
Thanks.
Raffi...
when your tunnel is Up, I'd try to start BGP peering between  Router B and Branch router through the Tunnel.
But it would be easier to run eBGP to get the prefixes to beat the EIGRP routes.
When the eBGP peering is esatblished between the Brach router and Router B through the tunnel, it shlould beat EIGRP prefixes automatically.
You just might need to tune Local Preference on Router B to make it the outgoing router for your traffic from your HQ to the Brange Office - I'm not sure if your router A and B are peering? And what's the default GW used in your HQ LAN?
HTH,
Milan
Hi Mohamed,
Since the AD value to BGP is less than EIGRP. BGP routes will be preferred by default.
To override this, you can configure BGP Backdoor. Then the traffic will flow via EIGRP.
"...AD value to BGP is less than EIGRP." is valid for eBGP but not for iBGP.
That's why I suggested to run eBGP through the tunnel.
BR,
Milan
Hi Milan,
EBGP Peering is done between router A and branch router. The routing is happening without issues. Link between Router B and branch router is through DIA for which GRE tunnel is configured and passed thorugh EIGRP.
When both r configured primary by default is by EBGP and secondary is thro DIA.  I need the primary to be DIA and backup thro EBGP.
ROuter A and Router B are not peering thro iBGP. HQ LAN default GW differs for different segment.
to make   the primary to be DIA and backup thro EBGP, you mihgt try to increase Local Preference of BGP prefixes received from the GRE tunnel.You would need to configure that on both tunnel sides.
There might be a problem with subnets where Router A is configured as a default GW though.
So you would need to configure Router A to prefer a path to Branch office via Router B somehow, or to exclude the subnets  using Router A as the default GW from the Local Preference increase (described above) on the Branch router.
In the later case those subnets will keep preferring EBGP path to/from Branch Office.
HTH,
Milan
