BGP Best Path Selection - Aggregate VS Redistributed
CSCO11598534
Level 2
Level 2
Hello all,
I would like your help, explaining why BGP picks the best path for the following situation. Please see the diagram. R1-R2-R3 are EIGRP neighbors. R2 and R3 are eBGP neighbors with R4.
Both R2 and R3 learn about the 1.1.1.1/32 prefix from R1
Both R2 and R3 do mutual redistribution between EIGRP and BGP
Both R2 and R3 locally create a BGP aggregate 1.1.0.0/16
I would expect that R4 would learn both aggregates created by R2 and R3. But here what really happens:
R2#sh ip bgp 1.1.0.0
BGP routing table entry for 1.1.0.0/16, version 10
Paths: (1 available, best #1, table default)
Advertised to update-groups:
Refresh Epoch 1
Local, (aggregated by 2 2.2.2.2)
0.0.0.0 from 0.0.0.0 (2.2.2.2)
Origin IGP, localpref 100, weight 32768, valid, aggregated, local, atomic-aggregate, best
R3#sh ip bgp 1.1.0.0
BGP routing table entry for 1.1.0.0/16, version 9
Paths: (2 available, best #2, table default)
Refresh Epoch 1
Local, (aggregated by 2 3.3.3.3)
0.0.0.0 from 0.0.0.0 (3.3.3.3)
Refresh Epoch 1
Local
23.23.23.2 from 0.0.0.0 (3.3.3.3)
Origin incomplete, metric 2560002816, localpref 100, weight 32768, valid, sourced, best
R4#sh ip bgp 1.1.0.0
BGP routing table entry for 1.1.0.0/16, version 12
Refresh Epoch 6
34.34.34.3 from 34.34.34.3 (3.3.3.3)
Origin incomplete, metric 2560002816, localpref 100, valid, external
Refresh Epoch 6
2, (aggregated by 2 2.2.2.2)
24.24.24.2 from 24.24.24.2 (2.2.2.2)
Origin IGP, metric 0, localpref 100, valid, external, atomic-aggregate, best
Either R2 or R3 (depends on who created the aggregate first), picks as best path the locally redistributed from EIGRP route that learned from the other router! (Please see R3 output)
Can someone please explain to me why this is the case?
Thank you!
Martin L
R4 did learn both routes; one from R2 and one from R3 but R4 BGP picks 1 Best by default based on Origin code I think.
in case of R3, I think following step #3 on the best patch selection made decision here. right?
Prefer the path that was locally originated via a network or aggregate BGP subcommand or through redistribution from an IGP.
Local paths that are sourced by the network or redistribute commands are preferred over local aggregates that are sourced by the aggregate-address command.
Local
Regards, ML
**Please Rate All Helpful Responses **
Martin L
Local
Regards, ML
Hey Martin,
Can you please provide a legit link where it is clearly stated that local network/redistribute commands are preferred over local aggregate?
