BGP problem
i can't ping from r1 to r6 or vice versa although this routes exist in the routing tables Screenshot (20).pngScreenshot (21).pngScreenshot (22).pngScreenshot (23).pngScreenshot (24).pngScreenshot (25).pngScreenshot (26).pngScreenshot (27).pngScreenshot (28).png
create pingable AS1
conf t
hostname R1
int s2/0
no sh
ip add 10.0.0.1 255.255.255.252
int s 2/1
no sh
ip add 10.0.0.5 255.255.255.252
int lo 0
ip add 1.1.1.1 255.255.255.255
router ospf 1
net 10.0.0.0 0.0.0.255 ar 0
net 1.1.1.1 0.0.0.0 ar 0
conf t
hostname R2
int s2/0
no sh
ip add 10.0.0.2 255.255.255.252
int s 2/1
no sh
ip add 12.0.0.1 255.255.255.252
int lo 0
ip add 2.2.2.2 255.255.255.255
router ospf 1
net 2.2.2.2 0.0.0.0 ar 0
conf t
hostname R3
int s2/0
no sh
ip add 10.0.0.6 255.255.255.252
int s 2/1
no sh
ip add 12.0.0.5 255.255.255.252
int lo 0
ip add 3.3.3.3 255.255.255.255
router ospf 1
net 3.3.3.3 0.0.0.0 ar 0
create pingable AS1
conf t
hostname R4
int s2/0
no sh
ip add 12.0.0.2 255.255.255.252
int s 2/1
no sh
ip add 11.0.0.1 255.255.255.252
int lo 0
ip add 4.4.4.4 255.255.255.255
router ospf 1
net 11.0.0.0 0.0.0.255 ar 0
net 4.4.4.4 0.0.0.0 ar 0
conf t
hostname R5
int s2/0
no sh
ip add 12.0.0.6 255.255.255.252
int s 2/1
no sh
ip add 11.0.0.5 255.255.255.252
int lo 0
ip add 5.5.5.5 255.255.255.255
router ospf 1
net 5.5.5.5 0.0.0.0 ar 0
conf t
hostname R6
int s2/0
no sh
ip add 11.0.0.2 255.255.255.252
int s 2/1
no sh
ip add 11.0.0.6 255.255.255.252
int lo 0
ip add 6.6.6.6 255.255.255.255
router ospf 1
net 6.6.6.6 0.0.0.0 ar 0
clear ip ospf process
y
BGP configuration
R1
router bgp 1
neighbor 2.2.2.2 remote-as 1
neighbor 2.2.2.2 update-source lo 0
neighbor 2.2.2.2 password cisco
neighbor 3.3.3.3 remote-as 1
neighbor 3.3.3.3 update-source lo 0
neighbor 3.3.3.3 password cisco
network 1.1.1.1 mask 255.255.255.255
R2
router bgp 1
neighbor 1.1.1.1 remote-as 1
neighbor 1.1.1.1 update-source lo 0
neighbor 1.1.1.1 password cisco
neighbor 1.1.1.1 next-hop-self
neighbor 4.4.4.4 remote-as 2
neighbor 4.4.4.4 update-source lo 0
neighbor 4.4.4.4 password cisco
neighbor 4.4.4.4 ebgp-multihop
ip route 4.4.4.4 255.255.255.255 12.0.0.2
R3
router bgp 1
neighbor 5.5.5.5 remote-as 2
neighbor 5.5.5.5 update-source lo 0
neighbor 5.5.5.5 password cisco
neighbor 5.5.5.5 ebgp-multihop
ip route 5.5.5.5 255.255.255.255 12.0.0.6
R4
router bgp 2
neighbor 6.6.6.6 remote-as 2
neighbor 6.6.6.6 update-source lo 0
neighbor 6.6.6.6 password cisco
neighbor 6.6.6.6 next-hop-self
neighbor 2.2.2.2 ebgp-multihop
ip route 2.2.2.2 255.255.255.255 12.0.0.1
R5
router bgp 2
neighbor 3.3.3.3 ebgp-multihop
ip route 3.3.3.3 255.255.255.255 12.0.0.5
R6
router bgp 2
net 6.6.6.6 mask 255.255.255.255
router bgp
maximum-paths 2
maximum-paths ibgp 2
Martin L
One of issues when pinging BGP is all networks (routes) along the patch must be advertised.  Solution is to do extended ping, ping 6.6.6.6 source 1.1.1.1
Another one is when peering BGP with loopbacks instead of directly connected routes, those loopbacks are not advertised.  Sort of "back hole" is created and traffic gets stuck.  Using Loopacks when Peering BGP is common inside organization (iBGP and ISPs) but outside of that I think we use directly connected links (eBGP).
Regards, ML
**Please Rate All Helpful Responses **
8 Replies 8
e.ciollaro
Level 9
Level 9
please post a sh ip route  and sh ip bgp for each router.
Bye
Enrico
thanks for your interest and your time
the problem is due to the fact that you are using the Loopback as update source interface but their IP is not in the routing table. For example R4 opath to R1 has next-hop 2.2.2.2, but 2.2.2. is not in it's routing table. Use the connected interface over the eBGP session and I guss it will work
Bye
enrico
PS Rate if useful
Or redistribute connected in BGP maybe another solution to avoid this "back hole", right?
Regards, ML
R4 has 2.2.2.2 in its routing table
Martin L
Regards, ML
thanks when trying extended ping , i found it works
i guess i understood the problem
when using normal ping to the external destionation it uses the physical interface as a source ip but the another AS routers does not have any information about this ip ,they know only about the loopback interface so the ping reply doesn't come back ,it will be droped from the another AS routers because they don't know the destination to reply to it ,great thanks alot
for your second tip, iam already using loopback static advertising in ebgp, SPs uses loopback peering between ASs because it is common to use dual conection between the ASBRs
