buffers, input errors, hardware or traffic issue.
rungemach
Community Member
Stumped and no one has an answer!
Errors that stall-out the router!
I am at a loss, we have done everything we can think of at this point, layer 1, cable, doubled DRAM to 512K, updated to latest code. Removed BGP and went to static routing. Below is the sh interface. Netflow show that the traffic going through the router is port 25. A larger than normal burst but no larger than 25mbps whihc is well under the line speed of 100mbps.
I need help fast, this has been going on for > week. TAC is stumped as well as CISCO SE.
inetrouter2#sh int
GigabitEthernet0/0 is up, line protocol is up
Hardware is MV96340 Ethernet, address is 000f.352e.d281 (bia 000f.352e.d281)
Description: Inside Interface$FW_INSIDE$
Internet address is xxx.xxx.xxx.xxx /24
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 24/255, rxload 9/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is T
output flow-control is XON, input flow-control is XON
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 3672000 bits/sec, 1276 packets/sec
5 minute output rate 9472000 bits/sec, 1579 packets/sec
91728321 packets input, 3448573575 bytes, 0 no buffer
Received 4399 broadcasts, 0 runts, 0 giants, 0 throttles
152889 input errors, 0 CRC, 0 frame, 0 overrun, 152893 ignored
0 watchdog, 0 multicast, 0 pause input
102913439 packets output, 314532730 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 lost carrier, 0 no carrier, 158076 pause output
GigabitEthernet0/1 is up, line protocol is up
Hardware is MV96340 Ethernet, address is 000f.352e.d282 (bia 000f.352e.d282)
Description: $ETH-WAN$Outside Interface$FW_OUTSIDE$
Internet address is xxx.xxx.xxx.xxx /29
reliability 255/255, txload 9/255, rxload 24/255
Last input 00:00:01, output 00:00:00, output hang never
Input queue: 0/75/4/0 (size/max/drops/flushes); Total output drops: 0
5 minute input rate 9416000 bits/sec, 1571 packets/sec
5 minute output rate 3643000 bits/sec, 1274 packets/sec
103609259 packets input, 94232125 bytes, 0 no buffer
Received 502 broadcasts, 0 runts, 0 giants, 3 throttles
118025 input errors, 0 CRC, 1 frame, 0 overrun, 118025 ignored
91797436 packets output, 3136134715 bytes, 0 underruns
0 lost carrier, 0 no carrier, 132446 pause output
Do you have speed/duplex parameters for both interfaces in autonegotiation mode on both sides?
If so try to change it to statically configured 100 Full-duplex. It should be done not only on router but also on switches (or other equipment) which connected to the ports.
//Mikhail Galiulin
I was hoping it would have been that simple, but alas, all intefaces are set for 100/full. All interfaces are reporting connected at 100/full
What type of equipment do you use on "the other side". Could you send the similar statistic from it.
It would be good if you can also attach routers config.
//Mikhail Galiulin
This is an internet facing device, there is no other side other than UUNet's equipment. We replaced the router on Friday, since then the errors are gone. This was a 2821 and we did purchase at the very beginning of the release. I noticed that there have been modifications to the board since then. Most importantly, the error has not reappeared for more than 72 hours. Prio to RMA on equipment we were having issues within just a couple of hours.
