Cannot ping to self interface(UP, UP)
cm6043
Level 4
Level 4
Hi all,
I have a strange issue in the router. I can ping to the remote PE ip(10.220.170.1) but can't ping local CE ip(10.220.170.2). Do anyone have similar case before ?
router#ping 10.220.170.2
Sending 5, 100-byte ICMP Echos to 10.220.170.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
novus-bkk-2237#ping 10.220.170.1
Sending 5, 100-byte ICMP Echos to 10.220.170.1, timeout is 2 seconds:
router#sh ip bgp su
BGP router identifier 172.16.255.197, local AS number 65505
BGP table version is 32, main routing table version 32
30 network entries using 3510 bytes of memory
31 path entries using 1612 bytes of memory
10/8 BGP path/bestpath attribute entries using 1240 bytes of memory
6 BGP AS-PATH entries using 144 bytes of memory
3 BGP extended community entries using 314 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 6820 total bytes of memory
BGP activity 30/0 prefixes, 31/0 paths, scan interval 60 secs
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
10.220.170.1 4 3491 19 10 32 0 0 00:05:36 27
router#
Leung Che man
Giuseppe Larosa
Hello Leung,
what type of interface is in use?
WAN interfaces when pinging their ip address send out the frame on wire.
for example ATM or serial interfaces.
Hope to help
Giuseppe
Hi Giuseppe,
It is a WIC-1T and router is C1841
Leung
Hello Leung,
as I've explained on serial lines the packet with SA=DA=interface address should be sent out on the wire.
For example in the case of FR multipoint subinterface you may need an additional frame-rel map statement to be able to ping successfully.
I see you have an eBGP session over it that looks like working
if you don't see other issues you should be fine.
Hope to help
Giuseppe
Hi Giuseppe,
Thanks for your information.
Leung
