checking cpu temperature through command line ?
mirehteshamali
Level 3
Level 3
hi all,
i want to check temperature of my core cisco router using cli ..how do i check this out using cammand line ?
i also have snmp monitoring , can some one please guide what object i have to enable to get temperature notifications ?
thanks
mrdogantr
Level 6
Level 6
     You can use "show enviroment all" command. And you can use links bellow for snmp.
http://tools.cisco.com/ITDIT/MIBS/servlet/index
http://tools.cisco.com/ITDIT/MIBS/MainServlet
hth
Muammer
