11-22-2023 11:03 PM
We recently upgraded our Cisco SDWAN devices to 12.12.2 for controllers and 17.12.2(ED) for C8500/8000v. When attaching new templates and pushing new configs the following error appears in the logs:
“Failed to obtain exclusive access to the IOS parser: % Authorization failed.”
The running configuration says successful in the vManage logs when pushing templates. But the actual running config does not update on the WAN edge. The local config on the vManage is updated.
11-22-2023 11:59 PM
I am sure you pushing the Config template using vManage - what is the version of vManage - check the compatibility :
Since its broken after upgrade, i suggest to Open a TAC due to latest version of code.
=====️ Preenayamo Vasudevam ️=====
12-06-2023 01:16 AM
12-26-2023 05:39 PM
I believe its TACACS and ISE/AD that's the issue.
