Cisco SDWAN Tracking - Timer
ismaelsaudi
Community Member
Hi!
I have implemented the service chaining functionality in my SD-WAN fabric (20.12.4), defined in the service VPN section of a Configuration Group, with the tracking option enabled to test when the firewall becomes unavailable.
Everything works correctly, but I think the tracking must have a probe (underneath) with a fairly high timer... Could you tell me what that timer is? Do you know if it is adjustable? If so, how can it be modified? I don't see anything in the vManage GUI where I can change the probe timing behavior.
0 Replies 0
