Client VPN split tunneling?
jon13
Community Member
Is it possible for a Client VPN user to use split tunneling with their connection to a MX device?
Thanks, Jon
25 Replies 25
PhilipDAth,
Thanks for the link. I'm using the VPN setup script and it is working great.
Questions:
1) If I use Meraki cloud authentication do I need the -DNSSuffix "[insert domain name]"? What is this for?
2) Meraki's documentation says to select "Require encryption (disconnect if server declines). Your script uses
-EncryptionLevel Optional. If I change it to -EncryptionLevel Required, I get an error saying / The current encryption selection requires EAP or MS-CHAPv2 logon security methods. PAP and CHAP do not support
Encryption settings 'Required' or 'Maximum'. : The parameter is incorrect.
Should I be worried about using the Optional encryption level?
Thanks, Jon1
Philip D'Ath
Meraki Community All-Star
If you go "ping host", windows will append the DNS suffix to the host name to form a FQDN. If you are using Active Directory and want to be able to access hosts using just their name then you'll need this. Otherwise you wont need it.
An IPSec VPN is bought up first, and then L2TP runs over it. Everything is encrypted, regardless of the option chosen.
The PowerShell script is working on Windows 10 machines. Win 7 doesn't recognize the add-vpnconnection command. Do I need to add a module to PowerShell? I am running as Administrator. Or is there a different script for Win 7 machines?
Thanks, jon1
Philip D'Ath
You might need to update the version of Powershell you are using - or the OS. 🙂
This is fantastic, thanks so much.
So, every time we need to have new routes, we need to run a new script. This seems not possible for end-users who are not much technically sound.
is there any development that the routes be pushed from meraki??
Philip D'Ath
Yes. Hence why many people deploy this via group policy. Then you can update all the user machines easily.
joey.debra
You should use the powershell command Add-VpnConnectionRoute.
If you add a bunch of VpnConnectionRoutes to an already defined VpnConnection those routes will only be added when the VPN is dialed.
The script from ifm.net.nz is a great way to set up a split tunnel. I have tested it manually and it works but when I try to use the script I get the error “Unable to remove existing outdated instance(s)........ Any suggestions?
Philip D'Ath
Have you already for a VPN connection with the same name as you are trying to create?
Are you running it from an Administrative PowerShell?
I did create one manually with the same name but have deleted it to run the script.
Yes, I am running it from an administrative PowerShell?
