Confirmation on HTTPS decryption
MICHAEL HORNE
Frequent Visitor
Frequent Visitor
Hello All,
Reading the documentation has led me to understand that the decryption of HTTPS traffic for Content filtering / inspection is not possible and and filtering on for HTTPS traffic will be based only on the host name only.
Can someone just confirm that SSL decryption is not possible?
Many thanks,
Michael
35 Replies 35
The Umbrella integration for MX is available, in Beta, now - with all the cautions that entails. You will need to be running MX r15 to access it, will need Advanced Security license in your Organization and will need Support to enable it for you. You will, of course, require an appropriate Umbrella subscription too. More information available here: https://documentation.meraki.com/MR/Other_Topics/Integrating_Cisco_Umbrella_with_Meraki_Networks
I don't have a date at which this would become a 'generally available' feature, but I would not expect it to be imminent.
shaun.oliver
Level 4
Level 4
It's unfortunate as there's a huge increase in malware/etc using HTTPS to bypass basic filtering.
SSL inspection is a big gap for the MX-line, certainly it'd be a very welcome feature!
Completely agree. This is really essential and it makes a mockery of many of the features that the MX line claims it can do.
- The advertised "Intrusion Prevention/IDS" feature (powered by SNORT) can't prevent any exploits from SSL enabled servers.
- Neither can the anti-malware feature (the MX will happily let you download a virus executable from an SSL enabled website
- The google search filtering doesn't work as they have moved to SSL.
- The "URL logging" feature (in beta) is completely unable to show the URLs for SSL websites. So we can't even view a history of a users google searches.
The majority of the web uses SSL now, and the MX appliance is therefore not fit for the purposes it advertises.
I've not heard anything about SSL Intercepting Proxy servers stopping working with a new version of TLS, do you have a link or some more information on that?
Interesting link.
I found that Symantec is selling a security appliance that can decrypt the draft standard of TLS 1.3, so the measures must still allow some implementations of MITM: https://www.symantec.com/theme/secure-decryption
I disagree with the assumption that because TLS 1.3 exists that this isn't worth looking into. Many big websites, e.g. PayPal have only just moved over to TLS 1.2 this year, which can be proxied. TLS 1.2 is not due to be depreciated at any point in the immediate future. Plus an SSL Proxy could be implemented with the existing transparent proxy software that the MX already runs on (squid), with some configuration changes.
I feel there is a huge missed opportunity here. The Meraki Systems Manager agent could massively simplify the deployment of a trusted SSL certificate to the client PCs and devices. It could be a complete security solution, at the moment it has a giant hole of 50% of the web through the middle of it (and growing).
I think the Symantec article you highlight is a little light on detail, on precisely what it can do (and what it can't). Fundamentally, if clients are required to fully verify the chain of trust, certificate-wise, with the target server (which is one of the TLS1.3 pre-reqs, as I understand it) then support for new TLS 1.3 cipher suites alone will not solve the conundrum. Of course, the adoption rate of TLS1.3 is always open to debate.
@GreenMan - It is making some pretty specific claims on this link:
https://www.symantec.com/products/ssl-visibility-appliance
"Enable the secure inspection of TLS 1.3 encrypted traffic"
"Enables the inspection of all ports and protocols of traffic including TLS 1.3 draft versions 18 - 21"
@BlakeRichardson - The Fortigate routers I linked to were $900 and $1800, so it is possible to get SSL inspection on products that are comparable in cost to the Meraki MX Security Appliances.
That isn't what depreciated means.
Robin St.Clair | Principal, Caithness Analytics | @uberseehandel
GreenMan IT seems like every other vendor has some sort of HTTPS decryption. Sophos XG, SonicWall, Fortinet even Cisco ASA 5506-X with FirePower all seem to be able to do this. As more traffic becomes SSL if I want to be honst to customers on features I think I have to point them back to the ASA line vs MX. With new products due out soon has there been any update on decryption?
It's clearly a typo for the word "deprecated."
BlakeRichardson
Meraki Community All-Star
@MICHAEL HORNE You are correct unless you use a vendor that provides an appliance capable of DPI-SSL however the cost for this sort of things is high and its not always perfect.
While TCP security is being improved the bad guys are also making use of the "invisibility" this gives them. This is why we can't rely fully on security appliances and we must be using good antivirus software.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
@BlakeRichardson By 'cost' do you mean price or performance?
Fortigate's entry-level NGFW 115 firewall range achieve throughput of 100 Mbps with SSL Inspection on low end Intel Atom CPUs:
https://www.forcepoint.com/sites/default/files/resources/files/datasheet_forcepoint_ngfw_appliances_specs_en.pdf
Their NGFW 321 doesn't specify the CPU used but it has a lower power draw than a Meraki MX84 and it achieves 150 Mbps throughput with SSL Inspection enabled.
https://www.forcepoint.com/sites/default/files/resources/files/datasheet_forcepoint_ngfw_300_series_en.pdf
BlakeRichardson
@ccnewmeraki Sorry I was meaning price not performance. One firewall I manage has a DPI SSL maximum throughout of 1Gbps so for most people that would be more than enough.
@ccnewmeraki;
Fortinet firewalls have FPGAs or custom chips to do the heavy lifting in their SSL inspection.
Dave Anderson
