CPU Utilization is high
Hi team,
               We are intermittently getting CPU utilization is high cisco 1800 router. Could i know the root cause on this?
Some logs attached for your reference..
KA-BANGLORE-RICHMOND-BM4417-RT-CIS-TCL#show interface
FastEthernet0/0 is up, line protocol is up
  Hardware is Gt96k FE, address is 04fe.7f59.e67e (bia 04fe.7f59.e67e)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 8/255, rxload 3/255
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 01:22:06
  Input queue: 2/75/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 1337000 bits/sec, 603 packets/sec
  30 second output rate 3255000 bits/sec, 578 packets/sec
     2242582 packets input, 637298931 bytes
     Received 76070 broadcasts (844 IP multicasts)
     0 runts, 0 giants, 559 throttles
     0 watchdog
     2949803 packets output, 2361407912 bytes, 0 underruns
     404 unknown protocol drops
     0 lost carrier, 0 no carrier
FastEthernet0/0.2 is up, line protocol is up
  Internet address is 10.4.53.3/24
  Encapsulation 802.1Q Virtual LAN, Vlan ID  2.
FastEthernet0/0.3 is up, line protocol is up
  Internet address is 172.21.62.1/24
  Encapsulation 802.1Q Virtual LAN, Vlan ID  3.
FastEthernet0/0.4 is up, line protocol is up
  Internet address is 10.70.48.1/23
  Encapsulation 802.1Q Virtual LAN, Vlan ID  4.
FastEthernet0/0.5 is up, line protocol is up
  Internet address is 10.2.155.1/24
  Encapsulation 802.1Q Virtual LAN, Vlan ID  5.
FastEthernet0/0.50 is up, line protocol is up
  Description: ***ARUBA_SEGMENT***
  Internet address is 10.4.56.1/24
  Encapsulation 802.1Q Virtual LAN, Vlan ID  50.
FastEthernet0/0.71 is up, line protocol is up
  Internet address is 10.4.54.3/24
  Encapsulation 802.1Q Virtual LAN, Vlan ID  71.
FastEthernet0/0.74 is up, line protocol is up
  Internet address is 10.16.22.1/24
  Encapsulation 802.1Q Virtual LAN, Vlan ID  74.
FastEthernet0/0.99 is up, line protocol is up
  Internet address is 10.16.21.3/24
  Encapsulation 802.1Q Virtual LAN, Vlan ID  99.
FastEthernet0/1 is up, line protocol is up
  Hardware is Gt96k FE, address is 04fe.7f59.e67f (bia 04fe.7f59.e67f)
  Internet address is 192.168.24.246/30
  MTU 1500 bytes, BW 20480 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 17/255, rxload 40/255
  30 second input rate 3236000 bits/sec, 572 packets/sec
  30 second output rate 1373000 bits/sec, 601 packets/sec
     2824027 packets input, 2328919486 bytes
     Received 509 broadcasts (13564 IP multicasts)
     78297 input errors, 157 CRC, 1 frame, 1 overrun, 0 ignored
     0 watchdog
     2137801 packets output, 646711927 bytes, 0 underruns
     0 unknown protocol drops
Tunnel0 is up, line protocol is up
  Hardware is Tunnel
  Interface is unnumbered. Using address of FastEthernet0/1 (192.168.24.246)
  MTU 17912 bytes, BW 100 Kbit/sec, DLY 50000 usec,
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source 192.168.24.246 (FastEthernet0/1), destination 192.168.24.177
   Tunnel Subblocks:
      src-track:
         Tunnel0 source tracking subblock associated with FastEthernet0/1
          Set of tunnels with source FastEthernet0/1, 1 member (includes iterators), on interface <OK>
  Tunnel protocol/transport PIM/IPv4
  Tunnel TOS/Traffic Class 0xC0,  Tunnel TTL 255
  Tunnel transport MTU 1472 bytes
  Tunnel is transmit only
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Last input never, output 00:03:15, output hang never
  Output queue: 0/0 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     58 packets output, 11090 bytes, 0 underruns
12 Replies 12
balaji.bandi
post show process cpu sorted | ex 0.00 and show process cpu history
show version
BB
sh r int fas
KA-BANGLORE-RICHMOND-BM4417-RT-CIS-TCL#sh int fastEthernet 0/0
     reliability 255/255, txload 29/255, rxload 3/255
  Last clearing of "show interface" counters 01:51:28
  Input queue: 12/75/0/0 (size/max/drops/flushes); Total output drops: 0
  30 second input rate 1238000 bits/sec, 682 packets/sec
  30 second output rate 11655000 bits/sec, 1266 packets/sec
     3488066 packets input, 979312083 bytes
     Received 90527 broadcasts (1228 IP multicasts)
     0 runts, 0 giants, 2450 throttles
     11 input errors, 11 CRC, 2 frame, 0 overrun, 0 ignored
     0 watchdog
     4865111 packets output, 4290026686 bytes, 0 underruns
 --More--              0 output errors, 0 collisions, 0 interface resets
 --More--              559 unknown protocol drops
 --More--              0 babbles, 0 late collision, 0 deferred
 --More--              0 lost carrier, 0 no carrier
 --More--              0 output buffer failures, 0 output buffers swapped out
KA-BANGLORE-RICHMOND-BM4417-RT-CIS-TCL#sh proc
KA-BANGLORE-RICHMOND-BM4417-RT-CIS-TCL#sh processes cpu
CPU utilization for five seconds: 85%/41%; one minute: 76%; five minutes: 78%
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
   1          16          15       1066  0.00%  0.00%  0.00%   0 Chunk Manager
   2        7784       19141        406  0.07%  0.03%  0.02%   0 Load Meter
   3           4           1       4000  0.00%  0.00%  0.00%   0 LICENSE AGENT
   4           0           1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
   5      164248       16420      10002  0.00%  0.18%  0.15%   0 Check heaps
   6        2236        1738       1286  0.00%  0.00%  0.00%   0 Pool Manager
   7           0           1          0  0.00%  0.00%  0.00%   0 DiscardQ Backgro
   8           0           2          0  0.00%  0.00%  0.00%   0 Timers
   9         220        3282         67  0.00%  0.00%  0.00%   0 WATCH_AFS
  10           0           1          0  0.00%  0.00%  0.00%   0 License Client N
  11           0           1          0  0.00%  0.00%  0.00%   0 OIR Handler
 --More--          PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
  12         180       19133          9  0.00%  0.00%  0.00%   0 IPC Event Notifi
  13          20        1596         12  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  14           0           1          0  0.00%  0.00%  0.00%   0 IPC Session Serv
  15           0           1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  16        1072       93218         11  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  17         864       93219          9  0.00%  0.00%  0.00%   0 IPC Deferred Por
  18           0           1          0  0.00%  0.00%  0.00%   0 IPC Process leve
  19           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  20          36        5470          6  0.00%  0.00%  0.00%   0 IPC Check Queue
  21           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat RX Cont
  22           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat TX Cont
  23          88        9577          9  0.00%  0.00%  0.00%   0 IPC Keep Alive M
  24         276       19136         14  0.00%  0.00%  0.00%   0 IPC Loadometer
  25         108        3191         33  0.00%  0.00%  0.00%   0 Environmental mo
  26           0           1          0  0.00%  0.00%  0.00%   0 Crash writer
  27           0           1          0  0.00%  0.00%  0.00%   0 Exception contro
  28        1136       93205         12  0.00%  0.00%  0.00%   0 BGP Scheduler
  29      254396      298944        850  0.23%  0.18%  0.18%   0 ARP Input
  30       14408       99763        144  0.00%  0.01%  0.00%   0 ARP Background
  31           0           2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  32           0           1          0  0.00%  0.00%  0.00%   0 ATM ASYNC PROC
  33           0           1          0  0.00%  0.00%  0.00%   0 CEF MIB API
  34           0           1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  35           0           1          0  0.00%  0.00%  0.00%   0 Policy Manager
  36           0           2          0  0.00%  0.00%  0.00%   0 DDR Timers
  37           0           2          0  0.00%  0.00%  0.00%   0 Entity MIB API
  38           0           2          0  0.00%  0.00%  0.00%   0 PrstVbl
  39           0           2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  40           0           1          0  0.00%  0.00%  0.00%   0 RMI RM Notify Wa
  41           0           2          0  0.00%  0.00%  0.00%   0 SMART
  42         956       95705          9  0.00%  0.00%  0.00%   0 GraphIt
  43           0           2          0  0.00%  0.00%  0.00%   0 Dialer event
  44           0           1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  45           0           2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
  46           0           1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  47      172584       51072       3379  0.00%  0.39%  0.80%   0 Net Background
  48           0           2          0  0.00%  0.00%  0.00%   0 IDB Work
  49          24         276         86  0.00%  0.00%  0.00%   0 Logger
  50        1148       95441         12  0.00%  0.00%  0.00%   0 TTY Background
  51           8           6       1333  0.00%  0.00%  0.00%   0 IF-MGR control p
  52           8          39        205  0.00%  0.00%  0.00%   0 IF-MGR event pro
  53           0           1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  54           0           2          0  0.00%  0.00%  0.00%   0 cpf_msg_holdq_pr
  55           0           1          0  0.00%  0.00%  0.00%   0 cpf_msg_rcvq_pro
  56           0           1          0  0.00%  0.00%  0.00%   0 Crypto PKI-HA
  57           0           1          0  0.00%  0.00%  0.00%   0 IKE HA Mgr
  58           0           1          0  0.00%  0.00%  0.00%   0 IPSEC HA Mgr
  59           4           2       2000  0.00%  0.00%  0.00%   0 rf task
  60           0           1          0  0.00%  0.00%  0.00%   0 RF High Priority
  61        1688       12359        136  0.00%  0.00%  0.00%   0 Net Input
  62         860       19227         44  0.00%  0.00%  0.00%   0 Compute load avg
  63       50248        4208      11941  0.00%  0.06%  0.00%   0 Per-minute Jobs
  64       67596       96101        703  0.15%  0.22%  0.23%   0 Per-Second Jobs
  65           0           1          0  0.00%  0.00%  0.00%   0 AggMgr Process
  66           0           1          0  0.00%  0.00%  0.00%   0 Token Daemon
  67           0         134          0  0.00%  0.00%  0.00%   0 Transport Port A
  68         828       28429         29  0.00%  0.00%  0.00%   0 HC Counter Timer
  69           0           2          0  0.00%  0.00%  0.00%   0 ESWPPM
  70           0           2          0  0.00%  0.00%  0.00%   0 Eswilp Storm Con
  71           0           1          0  0.00%  0.00%  0.00%   0 dev_device_inser
  72           0           1          0  0.00%  0.00%  0.00%   0 dev_device_remov
  73           0           2          0  0.00%  0.00%  0.00%   0 SM Monitor
  74           0           1          0  0.00%  0.00%  0.00%   0 RF_INTERDEV_DELA
  75           0           1          0  0.00%  0.00%  0.00%   0 RF_INTERDEV_SCTP
  76         848        5653        150  0.00%  0.00%  0.00%   0 EEM ED ND
  77           0           2          0  0.00%  0.00%  0.00%   0 EEM ED Identity
  78           0           1          0  0.00%  0.00%  0.00%   0 IGMP Snooping Pr
  79           0           1          0  0.00%  0.00%  0.00%   0 IGMP Snooping Re
  80         260           4      65000  0.00%  0.00%  0.00%   0 USB Startup
  81       10512       57992        181  0.07%  0.02%  0.00%   0 BGP I/O
  82           0           1          0  0.00%  0.00%  0.00%   0 Platform Compact
  83          68        3191         21  0.00%  0.00%  0.00%   0 Call Management
  84           0           1          0  0.00%  0.00%  0.00%   0 CF_INTERDEV_SCTP
  85         724       95450          7  0.00%  0.00%  0.00%   0 PI MATM Aging Pr
  86           0           2          0  0.00%  0.00%  0.00%   0 DTP Protocol
  87           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Mgr Proces
  88           0           1          0  0.00%  0.00%  0.00%   0 MAB Framework
  89           0           1          0  0.00%  0.00%  0.00%   0 EAP Framework
  90           0           1          0  0.00%  0.00%  0.00%   0 SMI Director DB
  91           0           1          0  0.00%  0.00%  0.00%   0 SMI CDP Update H
  92           0           1          0  0.00%  0.00%  0.00%   0 SMI Backup Proce
  93           0           2          0  0.00%  0.00%  0.00%   0 Ethernet CFM
  94        4360      599411          7  0.07%  0.02%  0.02%   0 Ethernet Timer C
  95       57748    11482971          5  0.55%  0.57%  0.54%   0 Ethernet Msec Ti
  96           0           2          0  0.00%  0.00%  0.00%   0 call_home_les_oi
  97         860       95471          9  0.00%  0.00%  0.00%   0 linktest
  98           0           2          0  0.00%  0.00%  0.00%   0 Dot11 Mgmt & Ass
  99           0           2          0  0.00%  0.00%  0.00%   0 Dot11 aaa proces
 100          12        1596          7  0.00%  0.00%  0.00%   0 pmkid
 101           0           2          0  0.00%  0.00%  0.00%   0 Dot11 auth Dot1x
 102           0           1          0  0.00%  0.00%  0.00%   0 Dot11 Mac Auth
 103           0           4          0  0.00%  0.00%  0.00%   0 AAA Server
 104           0           1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
 105           4           1       4000  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
 106        2248       14915        150  0.00%  0.00%  0.00%   0 CDP Protocol
 107           0           2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
 108           0           2          0  0.00%  0.00%  0.00%   0 Ethernet OAM Pro
 109           0           2          0  0.00%  0.00%  0.00%   0 Ethernet LMI
 110           0           2          0  0.00%  0.00%  0.00%   0 CEF switching ba
 111           0           1          0  0.00%  0.00%  0.00%   0 ADJ NSF process
 112           0           2          0  0.00%  0.00%  0.00%   0 ATM OAM Input
 113           4           2       2000  0.00%  0.00%  0.00%   0 ATM OAM TIMER
 114           0           2          0  0.00%  0.00%  0.00%   0 IPAM/ODAP Events
 115       22372     2867095          7  0.07%  0.15%  0.15%   0 IPAM Manager
 116           0           2          0  0.00%  0.00%  0.00%   0 IPAM Events
 117         700         432       1620  0.00%  0.00%  0.00%   0 IP ARP Adjacency
 118           0           1          0  0.00%  0.00%  0.00%   0 IP ARP Retry Age
 119    15240840     8590299       1774 39.03% 34.58% 36.05%   0 IP Input
 120           0         212          0  0.00%  0.00%  0.00%   0 ICMP event handl
 121          12           4       3000  0.00%  0.00%  0.00%   0 PIM register asy
 122           0           1          0  0.00%  0.00%  0.00%   0 IPv6 ping proces
 123          20         162        123  0.00%  0.00%  0.00%   0 MOP Protocols
 124           0           2          0  0.00%  0.00%  0.00%   0 OCE punted Pkts
 125           0           1          0  0.00%  0.00%  0.00%   0 LSP Tunnel FRR
 126           0           1          0  0.00%  0.00%  0.00%   0 MPLS Auto-Tunnel
 127           0           2          0  0.00%  0.00%  0.00%   0 PPP SIP
 128           0           2          0  0.00%  0.00%  0.00%   0 PPP Bind
 129           0           2          0  0.00%  0.00%  0.00%   0 PPP IP Route
 130           0           7          0  0.00%  0.00%  0.00%   0 SSH Event handle
 131           0           2          0  0.00%  0.00%  0.00%   0 Spanning Tree
 132           0           1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
 133           0          56          0  0.00%  0.00%  0.00%   0 SSM connection m
 134           0           1          0  0.00%  0.00%  0.00%   0 AC Switch
 135           0           1          0  0.00%  0.00%  0.00%   0 SSS Manager
 136           0           1          0  0.00%  0.00%  0.00%   0 SSS Policy Manag
 137           0           1          0  0.00%  0.00%  0.00%   0 SSS Feature Mana
 138        3968      373940         10  0.00%  0.01%  0.00%   0 SSS Feature Time
 139           4         320         12  0.00%  0.00%  0.00%   0 Authentication P
 140           0           1          0  0.00%  0.00%  0.00%   0 Auth-proxy AAA B
 141           0           2          0  0.00%  0.00%  0.00%   0 EAPoUDP Process
 142           0           2          0  0.00%  0.00%  0.00%   0 IP Host Track Pr
 143           0           2          0  0.00%  0.00%  0.00%   0 KRB5 AAA
 144           0           1          0  0.00%  0.00%  0.00%   0 IPC UDP Input
 145           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
 146           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
 147           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
 148           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
 149           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
 150           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
 151           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
 152          28        1596         17  0.00%  0.00%  0.00%   0 DFS flush period
 153       16456        1597      10304  0.23%  0.02%  0.00%   0 Licensing Auto U
 154           0           1          0  0.00%  0.00%  0.00%   0 FRR Background P
 155         108        2136         50  0.00%  0.00%  0.00%   0 CEF background p
 156           0           1          0  0.00%  0.00%  0.00%   0 fib_fib_bfd_sb e
 157           0           1          0  0.00%  0.00%  0.00%   0 Socket Timers
 158           0           2          0  0.00%  0.00%  0.00%   0 L2MM
 159           0           1          0  0.00%  0.00%  0.00%   0 MRD
 160           0           1          0  0.00%  0.00%  0.00%   0 IGMPSN
 161           0           2          0  0.00%  0.00%  0.00%   0 L2X Switching Ev
 162           0           1          0  0.00%  0.00%  0.00%   0 IP Traceroute
 163           0           2          0  0.00%  0.00%  0.00%   0 Routing Topology
 164         180          56       3214  0.00%  0.00%  0.00%   0 IP RIB Update
 165          32        1661         19  0.00%  0.00%  0.00%   0 IP Background
 166        4396        1089       4036  0.07%  0.02%  0.01%   0 IP Connected Rou
 167           0           2          0  0.00%  0.00%  0.00%   0 RLM groups Proce
 168        7612       81395         93  0.00%  0.02%  0.00%   0 TCP Timer
 169         196         214        915  0.00%  0.00%  0.00%   0 TCP Protocols
 170           4         321         12  0.00%  0.00%  0.00%   0 HTTP CORE
 171           0           7          0  0.00%  0.00%  0.00%   0 SNMP Timers
 172           4           4       1000  0.00%  0.00%  0.00%   0 SCTP Main Proces
 173           4           1       4000  0.00%  0.00%  0.00%   0 AAA System Acct
 174           0           1          0  0.00%  0.00%  0.00%   0 IUA Main Process
 175        1356       95557         14  0.00%  0.00%  0.00%   0 RUDPV1 Main Proc
 176           0           1          0  0.00%  0.00%  0.00%   0 bsm_timers
 177         804       95489          8  0.00%  0.00%  0.00%   0 bsm_xmt_proc
 178           0           2          0  0.00%  0.00%  0.00%   0 PPP Compress Inp
 179           0           2          0  0.00%  0.00%  0.00%   0 PPP Compress Res
 180           0           1          0  0.00%  0.00%  0.00%   0 COPS
 181           0           2          0  0.00%  0.00%  0.00%   0 Dialer Forwarder
 182       21848      127158        171  0.15%  0.10%  0.08%   0 CEF: IPv4 proces
 183          24          45        533  0.00%  0.00%  0.00%   0 ADJ background
 184      199352      134581       1481  0.07%  0.02%  0.05%   0 ADJ resolve proc
 185           0           3          0  0.00%  0.00%  0.00%   0 Flow Exporter Ti
 186           0           2          0  0.00%  0.00%  0.00%   0 Multicast Offloa
 187           0           1          0  0.00%  0.00%  0.00%   0 RARP Input
 188           4           2       2000  0.00%  0.00%  0.00%   0 static
 189           4           9        444  0.00%  0.00%  0.00%   0 MFIB Master back
 190          20        1599         12  0.00%  0.00%  0.00%   0 Call Home Timer
 191           0           7          0  0.00%  0.00%  0.00%   0 Collection proce
 192           0           1          0  0.00%  0.00%  0.00%   0 IPv6 Inspect Tim
 193           0           1          0  0.00%  0.00%  0.00%   0 IP IRDP
 194           0           1          0  0.00%  0.00%  0.00%   0 LAPB Process
 195           0           4          0  0.00%  0.00%  0.00%   0 Inter Chassis Pr
 196           0           2          0  0.00%  0.00%  0.00%   0 LFDp Input Proc
 197           0           2          0  0.00%  0.00%  0.00%   0 PPP NBF
 198           0           1          0  0.00%  0.00%  0.00%   0 PAD InCall
 199           0           2          0  0.00%  0.00%  0.00%   0 X.25 Background
 200        1228       94102         13  0.00%  0.00%  0.00%   0 PfR BR Learn
 201           0           1          0  0.00%  0.00%  0.00%   0 MQC Flow Event B
 202           0           2          0  0.00%  0.00%  0.00%   0 HQF Shaper Backg
 203           0           3          0  0.00%  0.00%  0.00%   0 RBSCP Background
 204           0           1          0  0.00%  0.00%  0.00%   0 VPDN call manage
 205           0           1          0  0.00%  0.00%  0.00%   0 IPS Process
 206           0           2          0  0.00%  0.00%  0.00%   0 IPS Auto Update
 207           4           2       2000  0.00%  0.00%  0.00%   0 SDEE Management
 208        1704      185981          9  0.00%  0.00%  0.00%   0 Inspect process
 209       41080        1608      25547  0.00%  0.02%  0.00%   0 BGP Scanner
 210          88        6168         14  0.00%  0.00%  0.00%   0 FW DP Inspect pr
 211        1664      185984          8  0.00%  0.00%  0.00%   0 CCE DP URLF cach
 212           0           2          0  0.00%  0.00%  0.00%   0 URL filter proc
 213           0           1          0  0.00%  0.00%  0.00%   0 Select Timers
 214          56           2      28000  0.00%  0.00%  0.00%   0 HTTP Process
 215           0           2          0  0.00%  0.00%  0.00%   0 CIFS API Process
 216           0           2          0  0.00%  0.00%  0.00%   0 CIFS Proxy Proce
 217           4           3       1333  0.00%  0.00%  0.00%   0 Crypto HW Proc
 218           0          13          0  0.00%  0.00%  0.00%   0 BGP Event
 219           0           2          0  0.00%  0.00%  0.00%   0 AAA Cached Serve
 220           4           2       2000  0.00%  0.00%  0.00%   0 ENABLE AAA
 221           0           1          0  0.00%  0.00%  0.00%   0 EM Background Pr
 222           0           1          0  0.00%  0.00%  0.00%   0 IDMGR CORE
 223           0           3          0  0.00%  0.00%  0.00%   0 LDAP process
 224           0           1          0  0.00%  0.00%  0.00%   0 Key chain liveke
 225           0           2          0  0.00%  0.00%  0.00%   0 LINE AAA
 226           0           4          0  0.00%  0.00%  0.00%   0 LOCAL AAA
 227           0          11          0  0.00%  0.00%  0.00%   0 MPLS Auto Mesh P
 228           4           2       2000  0.00%  0.00%  0.00%   0 TPLUS
 229           0           2          0  0.00%  0.00%  0.00%   0 VSP_MGR
 230           0           1          0  0.00%  0.00%  0.00%   0 FW_TEST_TRP
 231           0           1          0  0.00%  0.00%  0.00%   0 EPM MAIN PROCESS
 232       17016       10549       1613  0.00%  0.00%  0.00%   0 NIST rng proc
 233           0           3          0  0.00%  0.00%  0.00%   0 Crypto WUI
 234           0           2          0  0.00%  0.00%  0.00%   0 Crypto Support
 235           0           1          0  0.00%  0.00%  0.00%   0 IPSECv6 PS Proc
 236           0           2          0  0.00%  0.00%  0.00%   0 CSDB Timer proce
 237           0           1          0  0.00%  0.00%  0.00%   0 RPMS_PROC_MAIN
 238           0           2          0  0.00%  0.00%  0.00%   0 MMON PROCESS
 239       20640     2926918          7  0.15%  0.11%  0.09%   0 MMON MENG
 240           0           3          0  0.00%  0.00%  0.00%   0 crypto engine pr
 241           0           4          0  0.00%  0.00%  0.00%   0 Crypto CA
 242           0           1          0  0.00%  0.00%  0.00%   0 Crypto PKI-CRL
 243           0           1          0  0.00%  0.00%  0.00%   0 encrypt proc
 244       11636         992      11729  0.00%  0.00%  0.00%   0 crypto sw pk pro
 245           0           3          0  0.00%  0.00%  0.00%   0 CRYPTO MAP FREE
 246           0           1          0  0.00%  0.00%  0.00%   0 Crypto INT
 247           0           3          0  0.00%  0.00%  0.00%   0 Crypto IKE Dispa
 248           4           3       1333  0.00%  0.00%  0.00%   0 Crypto IKMP
 249           0           1          0  0.00%  0.00%  0.00%   0 IPSEC manual key
 250         164        4789         34  0.00%  0.00%  0.00%   0 IPSEC key engine
 251           0           2          0  0.00%  0.00%  0.00%   0 CRYPTO QoS proce
 252          12          15        800  0.00%  0.00%  0.00%   0 Crypto ACL
 253           0           1          0  0.00%  0.00%  0.00%   0 Crypto PAS Proc
 254           0           1          0  0.00%  0.00%  0.00%   0 GDOI GM Process
 255           0           1          0  0.00%  0.00%  0.00%   0 UNICAST REKEY
 256           0           1          0  0.00%  0.00%  0.00%   0 UNICAST REKEY AC
 257         716       95761          7  0.00%  0.00%  0.00%   0 Crypto Device Up
 258           0           2          0  0.00%  0.00%  0.00%   0 Multi-ISA Event
 259           0           1          0  0.00%  0.00%  0.00%   0 Multi-ISA Cleanu
 260           0           1          0  0.00%  0.00%  0.00%   0 PM Callback
 261           0           1          0  0.00%  0.00%  0.00%   0 Licensing MIB pr
 262           0           2          0  0.00%  0.00%  0.00%   0 Control-plane ho
 263        4292      478534          8  0.07%  0.02%  0.00%   0 Atheros LED Ctro
 264           0           1          0  0.00%  0.00%  0.00%   0 DATA Transfer Pr
 265           0           1          0  0.00%  0.00%  0.00%   0 DATA Collector
 266         764        1106        690  0.07%  0.06%  0.02%   0 Exec
 267           8          60        133  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
 268           0           1          0  0.00%  0.00%  0.00%   0 Test AAA Client
 269           0           1          0  0.00%  0.00%  0.00%   0 DCM Transfer Pro
 270           0           1          0  0.00%  0.00%  0.00%   0 DCM Core Process
 271          76        9573          7  0.00%  0.00%  0.00%   0 RMON Recycle Pro
 272           0           2          0  0.00%  0.00%  0.00%   0 RMON Deferred Se
 273           0           1          0  0.00%  0.00%  0.00%   0 Syslog Traps
 274           0           2          0  0.00%  0.00%  0.00%   0 EEM ED Routing
 275          24         174        137  0.00%  0.00%  0.00%   0 EEM ED Syslog
 276           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Track
 277           4           2       2000  0.00%  0.00%  0.00%   0 EEM ED Resource
 278         200        2993         66  0.00%  0.00%  0.00%   0 Crypto cTCP proc
 279           4           2       2000  0.00%  0.00%  0.00%   0 VLAN Manager
 280          20         798         25  0.00%  0.00%  0.00%   0 DHCPD Timer
 281           8         182         43  0.00%  0.00%  0.00%   0 EEM Server
 283          28           2      14000  0.00%  0.00%  0.00%   0 Call Home proces
 284         128         147        870  0.00%  0.00%  0.00%   0 Syslog
 285           0           1          0  0.00%  0.00%  0.00%   0 IP SLAs Ethernet
 286           4           2       2000  0.00%  0.00%  0.00%   0 EEM Policy Direc
 287        1304         435       2997  0.23%  0.13%  0.07% 194 Virtual Exec
 288           0           3          0  0.00%  0.00%  0.00%   0 EEM ED CLI
 289           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Counter
 290           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Interface
 291           0           3          0  0.00%  0.00%  0.00%   0 EEM ED IOSWD
 292           0           3          0  0.00%  0.00%  0.00%   0 EEM ED None
 293           0           3          0  0.00%  0.00%  0.00%   0 EEM ED OIR
 294           4           4       1000  0.00%  0.00%  0.00%   0 EEM ED RF
 295           0           3          0  0.00%  0.00%  0.00%   0 EEM ED SNMP
 296           4           3       1333  0.00%  0.00%  0.00%   0 EEM ED SNMP Obje
 297           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Ipsla
 298           4           2       2000  0.00%  0.00%  0.00%   0 EEM ED SNMP Noti
 299          16        4518          3  0.00%  0.00%  0.00%   0 EEM ED Timer
 300           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Test
 301           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Config
 302           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Env
 303           0           3          0  0.00%  0.00%  0.00%   0 EM ED GOLD
 304           0           2          0  0.00%  0.00%  0.00%   0 EEM ED Nf
 305           0           3          0  0.00%  0.00%  0.00%   0 EEM ED RPC
 306          40        1596         25  0.00%  0.00%  0.00%   0 DHCPD Database
 307           0           2          0  0.00%  0.00%  0.00%   0 MRIB Process
 308           0           2          0  0.00%  0.00%  0.00%   0 Key Proc
 309           0           1          0  0.00%  0.00%  0.00%   0 tHUB
 311        2896        3489        830  0.00%  0.00%  0.00%   0 DHCPD Receive
 312       19952      969180         20  0.07%  0.09%  0.07%   0 IGMP Input
 313       46468     2045527         22  0.23%  0.28%  0.26%   0 PIM Process
 314       12640      955146         13  0.07%  0.07%  0.07%   0 Mwheel Process
 315        1492        6535        228  0.00%  0.00%  0.00%   0 MRIB Trans
 316           8           4       2000  0.00%  0.00%  0.00%   0 MFIB_init
 317       79976     5657602         14  0.39%  0.55%  0.55%   0 HSRP Common
 318           0           3          0  0.00%  0.00%  0.00%   0 HSRP IPv4
 319          20          85        235  0.00%  0.00%  0.00%   0 MFIB_cable
 320       33920     4523519          7  0.07%  0.23%  0.24%   0 MFIB_mrib_write
 321        1732        6573        263  0.00%  0.00%  0.00%   0 MFIB_mrib_read
 322         156       11967         13  0.00%  0.00%  0.00%   0 MFIB_rate
 323          80         109        733  0.00%  0.00%  0.00%   0 BGP Task
 325           0          13          0  0.00%  0.00%  0.00%   0 TCP Listener
 326      133428    21942178          6  0.23%  1.37%  1.39%   0 IP SLAs XOS Even
 327       27564       56058        491  0.00%  0.01%  0.00%   0 IP SNMP
 328        6928       27129        255  0.00%  0.00%  0.00%   0 PDU DISPATCHER
 329       39140       27111       1443  0.07%  0.03%  0.03%   0 SNMP ENGINE
 330           0           2          0  0.00%  0.00%  0.00%   0 IP SNMPV6
 331           0           1          0  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
 332        4308        1075       4007  0.00%  0.00%  0.00%   0 SNMP Traps
 333        9264      109555         84  0.00%  0.02%  0.02%   0 NTP
 334          12        1596          7  0.00%  0.00%  0.00%   0 Time Range Proce
 335        5292      122443         43  0.00%  0.01%  0.00%   0 BGP Router
 336           0           1          0  0.00%  0.00%  0.00%   0 cpf_process_tpQ
KA-BANGLORE-RICHMOND-BM4417-RT-CIS-TCL#  sh mem
KA-BANGLORE-RICHMOND-BM4417-RT-CIS-TCL#sh memory ?
  allocating-process  Show allocating process name
  dead                Memory owned by dead processes
  debug               Memory debugging commands
  failures            Memory failures
  fast                Fast memory stats
  fragment            Summary of memory fragment information
  free                Free memory stats
  io                  IO memory stats
  lite-chunks         Malloc lite info
  multibus            Multibus memory stats
  overflow            memory overflow corrections
  pci                 PCI memory stats
  processor           Processor memory stats
  statistics          Mempool Statistics
  summary             Summary of memory usage per alloc PC
  transient           Transient memory stats
  |                   Output modifiers
  <cr>
KA-BANGLORE-RICHMOND-BM4417-RT-CIS-TCL#sh memory suma
KA-BANGLORE-RICHMOND-BM4417-RT-CIS-TCL#sh memory summary
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor   663F5CC0   140550976    38161016   102389960   102058896   102195920
      I/O   EEA00000    23068672     4574448    18494224    18484224    18422428
          Processor memory
Alloc PC        Size     Blocks      Bytes    What
0x60016814 0000000380 0000000001 0000000380    Init
0x6001A770 0000001024 0000000004 0000004096    AF filter
0x6001A930 0000000028 0000000004 0000000112    AF entry
0x6001A930 0000000080 0000000002 0000000160    AF entry
0x6001A930 0000000084 0000000001 0000000084    AF entry
0x6001A930 0000000088 0000000005 0000000440    AF entry
0x6001A930 0000000092 0000000001 0000000092    AF entry
0x6001A930 0000000096 0000000001 0000000096    AF entry
0x6001A930 0000000100 0000000002 0000000200    AF entry
0x6001A930 0000000028 0000000003 0000000084    (fragment) (Free Blocks)
0x6001A930 0000000048 0000000001 0000000048    (fragment) (Free Blocks)
0x6001B95C 0000001160 0000000008 0000009280    *In-use Packet Header*
 --More--
KA-BANGLORE-RICHMOND-BM4417-RT-CIS-TCL#unde
KA-BANGLORE-RICHMOND-BM4417-RT-CIS-TCL#undebug all
All possible debugging has been turned off
CPU utilization for five seconds: 86%/42%; one minute: 80%; five minutes: 78%
   2        7840       19164        409  0.00%  0.03%  0.02%   0 Load Meter
   5      164528       16442      10006  0.00%  0.20%  0.15%   0 Check heaps
   6        2244        1740       1289  0.00%  0.00%  0.00%   0 Pool Manager
   9         220        3285         66  0.00%  0.00%  0.00%   0 WATCH_AFS
 --More--           12         180       19156          9  0.00%  0.00%  0.00%   0 IPC Event Notifi
 --More--           13          20        1599         12  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
KA-BANGLORE-RICHMOND-BM4417-RT-CIS-TCL#sh processes cpu sorted
CPU utilization for five seconds: 11%/6%; one minute: 11%; five minutes: 14%
 326      139448    22447099          6  2.07%  2.07%  2.07%   0 IP SLAs XOS Even
  95       60260    11755187          5  0.87%  0.72%  0.72%   0 Ethernet Msec Ti
 317       83060     5790301         14  0.63%  0.62%  0.63%   0 HSRP Common
 313       48344     2094943         23  0.31%  0.28%  0.28%   0 PIM Process
 320       35348     4629614          7  0.31%  0.31%  0.31%   0 MFIB_mrib_write
  64       70040       98434        711  0.23%  0.23%  0.23%   0 Per-Second Jobs
 115       23352     2935426          7  0.15%  0.16%  0.15%   0 IPAM Manager
 119    15734544     8847476       1778  0.15%  0.17%  1.58%   0 IP Input
  81       10780       59500        181  0.07%  0.01%  0.00%   0 BGP I/O
 314       13104      977966         13  0.07%  0.07%  0.07%   0 Mwheel Process
  68         844       29123         28  0.07%  0.00%  0.00%   0 HC Counter Timer
 239       21660     2996930          7  0.07%  0.11%  0.10%   0 MMON MENG
 182       22692      130573        173  0.07%  0.08%  0.07%   0 CEF: IPv4 proces
  13          20        1635         12  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  17         900       95484          9  0.00%  0.00%  0.00%   0 IPC Deferred Por
  16        1124       95483         11  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  12         184       19598          9  0.00%  0.00%  0.00%   0 IPC Event Notifi
  20          48        5603          8  0.00%  0.00%  0.00%   0 IPC Check Queue
  23          96        9809          9  0.00%  0.00%  0.00%   0 IPC Keep Alive M
  24         292       19601         14  0.00%  0.00%  0.00%   0 IPC Loadometer
  29      257832      304932        845  0.00%  0.04%  0.07%   0 ARP Input
  30       14860      102182        145  0.00%  0.01%  0.01%   0 ARP Background
  25         112        3268         34  0.00%  0.00%  0.00%   0 Environmental mo
  42         992       98028         10  0.00%  0.00%  0.00%   0 GraphIt
  28        1168       95469         12  0.00%  0.00%  0.00%   0 BGP Scheduler
  49          24         282         85  0.00%  0.00%  0.00%   0 Logger
  50        1184       97754         12  0.00%  0.00%  0.00%   0 TTY Background
  61        1712       12506        136  0.00%  0.00%  0.00%   0 Net Input
  62         876       19692         44  0.00%  0.00%  0.00%   0 Compute load avg
  63       51484        4304      11961  0.00%  0.03%  0.00%   0 Per-minute Jobs
   9         236        3424         68  0.00%  0.00%  0.00%   0 WATCH_AFS
  76         880        5822        151  0.00%  0.00%  0.00%   0 EEM ED ND
  47      176380       52329       3370  0.00%  0.00%  0.00%   0 Net Background
  85         736       97757          7  0.00%  0.00%  0.00%   0 PI MATM Aging Pr
   5      168664       16832      10020  0.00%  0.20%  0.15%   0 Check heaps
  94        4552      614150          7  0.00%  0.02%  0.02%   0 Ethernet Timer C
  97         908       97777          9  0.00%  0.00%  0.00%   0 linktest
 100          12        1635          7  0.00%  0.00%  0.00%   0 pmkid
 106        2308       15279        151  0.00%  0.00%  0.00%   0 CDP Protocol
 117         704         443       1589  0.00%  0.00%  0.00%   0 IP ARP Adjacency
   2        8020       19607        409  0.00%  0.03%  0.02%   0 Load Meter
  83          68        3268         20  0.00%  0.00%  0.00%   0 Call Management
 123          20         166        120  0.00%  0.00%  0.00%   0 MOP Protocols
 138        4136      382934         10  0.00%  0.02%  0.00%   0 SSS Feature Time
 139           4         327         12  0.00%  0.00%  0.00%   0 Authentication P
 152          28        1635         17  0.00%  0.00%  0.00%   0 DFS flush period
 153       16888        1635      10329  0.00%  0.01%  0.00%   0 Licensing Auto U
 155         112        2192         51  0.00%  0.00%  0.00%   0 CEF background p
   6        2340        1778       1316  0.00%  0.00%  0.00%   0 Pool Manager
   1          16          16       1000  0.00%  0.00%  0.00%   0 Chunk Manager
 165          32        1700         18  0.00%  0.00%  0.00%   0 IP Background
 166        4640        1143       4059  0.00%  0.00%  0.00%   0 IP Connected Rou
 169         200         220        909  0.00%  0.00%  0.00%   0 TCP Protocols
 170           4         328         12  0.00%  0.00%  0.00%   0 HTTP CORE
 175        1380       97847         14  0.00%  0.00%  0.00%   0 RUDPV1 Main Proc
 177         828       97779          8  0.00%  0.00%  0.00%   0 bsm_xmt_proc
 184      204852      139052       1473  0.00%  0.09%  0.16%   0 ADJ resolve proc
 190          20        1639         12  0.00%  0.00%  0.00%   0 Call Home Timer
 200        1264       96370         13  0.00%  0.00%  0.00%   0 PfR BR Learn
 208        1784      190434          9  0.00%  0.00%  0.00%   0 Inspect process
 209       42116        1647      25571  0.00%  0.01%  0.00%   0 BGP Scanner
 210          92        6316         14  0.00%  0.00%  0.00%   0 FW DP Inspect pr
 211        1776      190436          9  0.00%  0.00%  0.00%   0 CCE DP URLF cach
 232       17660       10924       1616  0.00%  0.00%  0.00%   0 NIST rng proc
 250         164        4904         33  0.00%  0.00%  0.00%   0 IPSEC key engine
 257         736       98048          7  0.00%  0.00%  0.00%   0 Crypto Device Up
 263        4484      489956          9  0.00%  0.01%  0.00%   0 Atheros LED Ctro
 266       10188        3393       3002  0.00%  0.20%  0.51%   0 Exec
 267           8          61        131  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
 271          76        9801          7  0.00%  0.00%  0.00%   0 RMON Recycle Pro
 275          24         177        135  0.00%  0.00%  0.00%   0 EEM ED Syslog
 278         204        3064         66  0.00%  0.00%  0.00%   0 Crypto cTCP proc
 280          20         817         24  0.00%  0.00%  0.00%   0 DHCPD Timer
 281          12         189         63  0.00%  0.00%  0.00%   0 EEM Server
 284         128         150        853  0.00%  0.00%  0.00%   0 Syslog
 287        8396        1394       6022  0.00%  0.03%  0.40% 194 Virtual Exec
 299          20        4622          4  0.00%  0.00%  0.00%   0 EEM ED Timer
 306          44        1634         26  0.00%  0.00%  0.00%   0 DHCPD Database
 310         272         130       2092  0.00%  0.00%  0.03% 195 Virtual Exec
 311        2916        3522        827  0.00%  0.00%  0.00%   0 DHCPD Receive
 312       20636      992261         20  0.00%  0.07%  0.07%   0 IGMP Input
 315        1508        6662        226  0.00%  0.00%  0.00%   0 MRIB Trans
 321        1748        6695        261  0.00%  0.00%  0.00%   0 MFIB_mrib_read
 322         160       12251         13  0.00%  0.00%  0.00%   0 MFIB_rate
 168        7740       84424         91  0.00%  0.02%  0.00%   0 TCP Timer
 327       28168       57342        491  0.00%  0.00%  0.00%   0 IP SNMP
 328        7052       27745        254  0.00%  0.00%  0.00%   0 PDU DISPATCHER
 329       40088       27727       1445  0.00%  0.00%  0.00%   0 SNMP ENGINE
 332        4540        1109       4093  0.00%  0.00%  0.00%   0 SNMP Traps
 333        9524      112185         84  0.00%  0.03%  0.02%   0 NTP
 334          12        1634          7  0.00%  0.00%  0.00%   0 Time Range Proce
 335        5428      125392         43  0.00%  0.00%  0.00%   0 BGP Router
KA-BANGLORE-RICHMOND-BM4417-RT-CIS-TCL#q ter
KA-BANGLORE-RICHMOND-BM4417-RT-CIS-TCL#terminal len
KA-BANGLORE-RICHMOND-BM4417-RT-CIS-TCL#terminal length 24
KA-BANGLORE-RICHMOND-BM4417-RT-CIS-TCL#exit
the output too length to read
post only asked information please (use exact command suggested)
show version
as of now i see some IP input, post asked above output correctly.
BB
What is the WAN speed of this router?
KA-BANGLORE-RICHMOND-BM4417-RT-CIS-TCL#sh run
Building configuration...
Current configuration : 14187 bytes
! Last configuration change at 17:21:08 IST Tue Feb 2 2021 by rsadmin
! NVRAM config last updated at 19:27:19 IST Mon Feb 1 2021 by rsadmin
version 15.1
service password-encryption
hostname KA-BANGLORE-RICHMOND-BM4417-RT-CIS-TCL
boot-start-marker
boot-end-marker
logging buffered 409600
logging rate-limit all 10 except errors
logging console critical
enable secret 5 $1$mfVD$feR8CyARMq4M2fm0Iors01
no aaa new-model
 --More--         !
 --More--         clock timezone IST 5 30
 --More--         dot11 syslog
 --More--         ip source-route
 --More--         !
 --More--         !
 --More--         !
 --More--         !
 --More--         !
 --More--         ip cef
 --More--         no ip bootp server
 --More--         no ip domain lookup
 --More--         ip domain name Indiainfoline.com
 --More--         ip multicast-routing
 --More--         no ipv6 cef
 --More--         !
 --More--         multilink bundle-name authenticated
 --More--         !
 --More--         crypto pki token default removal timeout 0
 --More--         !
 --More--         !
 --More--         !
 --More--         !
 --More--         license udi pid CISCO1841 sn FHK1406723G
 --More--         username nmadmin privilege 15 secret 5 $1$rLT/$YpTAIu1E6AtNX3xmxyMaK/
 --More--         username L2admin privilege 2 secret 5 $1$zN3F$OMndJ5kjh3ZL18h4YUcWV0
 --More--         username orian.admin privilege 3 secret 5 $1$tce.$iavaefNLK5RTk1YgahoSu.
 --More--         username rsadmin privilege 15 password 7 095E5D081D081E1C2B5D5679
 --More--         username L3admin privilege 15 password 7 02250D4808092F761417
 --More--         username L1admin secret 5 $1$7Uh4$0r4jGTSTQNRdhHPqNgKAQ.
 --More--         !
 --More--         redundancy
 --More--         !
 --More--         !
 --More--         ip ssh version 2
 --More--         !
 --More--         class-map match-all BANG_EXPERENCE_CLASS_OUT
 --More--          match access-group name BANGVC_OUT
 --More--         class-map match-any KASEYA_CLASS_OUT
 --More--          match access-group name KASEYA_CLASS_OUT
 --More--         class-map match-all BLRRICHVC_CLASS_IN
 --More--          match access-group name BLRRICHVC_ACL_IN
 --More--         class-map match-all ASKNIRMAL_IN
 --More--          match access-group name asknirmal_in
 --More--         class-map match-all SAPPIRE_IN
 --More--          match access-group name SAPP_IN
 --More--         class-map match-all BANG_EXPERENCE_CLASS_IN
 --More--          match access-group name BANGVC_IN
 --More--         class-map match-all ASKNIRMAL_OUT
 --More--         class-map match-all SAPPIRE_OUT
 --More--          match access-group name SAPP_OUT
 --More--         !
 --More--         !
 --More--         policy-map BANG_EXPERENCE_CLASS_OUT
 --More--          class BANG_EXPERENCE_CLASS_OUT
 --More--           police cir 6291000 bc 20000000
 --More--            conform-action transmit
 --More--            exceed-action drop
 --More--          class SAPPIRE_OUT
 --More--           police cir 6291000 bc 20000000 be 20000000
 --More--            violate-action drop
 --More--         policy-map BANG_EXPERENCE_POLICY_IN
 --More--          class BANG_EXPERENCE_CLASS_IN
 --More--          class SAPPIRE_IN
 --More--         policy-map RICH_CLASS_OUT
 --More--          class KASEYA_CLASS_OUT
 --More--           police cir 1024000 bc 256000
 --More--         policy-map BLRRICHVC_POLICY_IN
 --More--          class BLRRICHVC_CLASS_IN
 --More--           police cir 3145500
 --More--          class ASKNIRMAL_IN
 --More--           police cir 2048000
 --More--          class class-default
 --More--         !
 --More--         !
 --More--         !
 --More--         !
 --More--         !
 --More--         !
 --More--         !
 --More--         !
 --More--         interface FastEthernet0/0
 --More--          no ip address
 --More--          no ip redirects
 --More--          no ip unreachables
 --More--          no ip proxy-arp
 --More--          no ip route-cache
 --More--          load-interval 30
 --More--          duplex auto
 --More--          speed auto
 --More--         !
 --More--         interface FastEthernet0/0.2
 --More--          encapsulation dot1Q 2
 --More--          ip address 10.4.53.3 255.255.255.0
 --More--          ip helper-address 172.24.41.115
 --More--          ip helper-address 172.26.20.31
 --More--          ip helper-address 172.26.16.40
 --More--          ip accounting output-packets
 --More--          ip flow ingress
 --More--          ip flow egress
 --More--          ip pim query-interval 1
 --More--          ip pim sparse-mode
 --More--          standby 2 ip 10.4.53.1
 --More--          standby 2 timers 1 6
 --More--          standby 2 priority 200
 --More--          standby 2 preempt
 --More--          standby 2 track 10 decrement 20
 --More--          ip igmp static-group 239.255.255.255 source 172.16.1.103
 --More--          ip igmp static-group 224.5.6.21 source 172.16.1.70
 --More--          no cdp enable
 --More--         !
 --More--         interface FastEthernet0/0.3
 --More--          encapsulation dot1Q 3
 --More--          ip address 172.21.62.1 255.255.255.0
 --More--         !
 --More--         interface FastEthernet0/0.4
 --More--          encapsulation dot1Q 4
 --More--          ip address 10.70.48.1 255.255.254.0
 --More--          ip helper-address 172.17.14.61
 --More--          ip helper-address 10.70.68.61
 --More--         !
 --More--         interface FastEthernet0/0.5
 --More--          encapsulation dot1Q 5
 --More--          ip address 10.2.155.1 255.255.255.0
 --More--         !
 --More--         interface FastEthernet0/0.50
 --More--          description ***ARUBA_SEGMENT***
 --More--          encapsulation dot1Q 50
 --More--          ip address 10.4.56.1 255.255.255.0
 --More--         !
 --More--         interface FastEthernet0/0.71
 --More--          encapsulation dot1Q 71
 --More--          ip address 10.4.54.3 255.255.255.0
 --More--          standby 71 ip 10.4.54.1
 --More--          standby 71 timers 1 6
 --More--          standby 71 priority 200
 --More--          standby 71 preempt
 --More--         !
 --More--         interface FastEthernet0/0.74
 --More--          encapsulation dot1Q 74
 --More--          ip address 10.16.22.1 255.255.255.0
 --More--          ip access-group beta_mobile in
 --More--          ip helper-address 192.168.175.15
 --More--         !
 --More--         interface FastEthernet0/0.99
 --More--          encapsulation dot1Q 99
 --More--          ip address 10.16.21.3 255.255.255.0
 --More--          ip multicast boundary Multicast_Boundary
 --More--          standby 99 ip 10.16.21.1
 --More--          standby 99 timers 1 6
 --More--          standby 99 priority 130
 --More--          standby 99 preempt
 --More--          standby 99 track 10 decrement 60
 --More--          service-policy input BANG_EXPERENCE_POLICY_IN
 --More--          service-policy output BANG_EXPERENCE_CLASS_OUT
 --More--         !
 --More--         interface FastEthernet0/1
 --More--          bandwidth 20480
 --More--          ip address 192.168.24.246 255.255.255.252
 --More--          ip access-group block_out in
 --More--          speed 100
 --More--          full-duplex
 --More--         !
 --More--         router bgp 64537
 --More--          bgp log-neighbor-changes
 --More--          redistribute connected
 --More--          neighbor 192.168.24.245 remote-as 64522
 --More--          neighbor 192.168.24.245 timers 3 60
 --More--          neighbor 192.168.24.245 allowas-in 6
 --More--          neighbor 192.168.24.245 soft-reconfiguration inbound
 --More--         !
 --More--         ip forward-protocol nd
 --More--         no ip http server
 --More--         no ip http secure-server
 --More--         !
 --More--         ip flow-export source FastEthernet0/1
 --More--         ip flow-export version 9
 --More--         ip flow-export destination 172.24.41.68 2055
 --More--         ip flow-export destination 172.26.20.38 2055
 --More--         !
 --More--         ip pim rp-address 192.168.24.177
 --More--         !
 --More--         ip access-list standard Multicast_Boundary
 --More--          permit 239.255.255.255
 --More--          permit 224.5.6.21
 --More--         ip access-list standard Prepend
 --More--         ip access-list standard SNMP_Server
 --More--          permit 172.26.20.38
 --More--          permit 172.24.41.68
 --More--          deny   any
 --More--         ip access-list standard ntp_server
 --More--          permit 192.168.149.251
 --More--          permit 172.26.20.251
 --More--          permit 172.24.41.44
 --More--          permit 172.24.41.39
 --More--          deny   any
 --More--         ip access-list standard remote_access
 --More--          permit 172.24.41.211
 --More--          permit 172.24.41.210
 --More--          permit 172.26.20.46
 --More--          permit 172.24.41.40
 --More--          permit 172.26.3.13
 --More--          permit 172.24.41.95
 --More--          permit 192.168.180.0 0.0.0.255
 --More--          permit 192.168.130.0 0.0.0.255
 --More--          permit 10.10.56.0 0.0.0.255
 --More--          permit 10.16.21.0 0.0.0.255
 --More--          permit 10.4.54.0 0.0.0.255
 --More--          permit 10.4.53.0 0.0.0.255
 --More--          permit any
 --More--          deny   any
 --More--         !
 --More--         ip access-list extended BANGVC_OUT
 --More--          permit ip host 10.4.56.240 any
 --More--          permit ip host 172.21.62.10 any
 --More--         ip access-list extended Block
 --More--          deny   tcp host 10.4.53.59 any
 --More--          deny   tcp host 172.21.62.12 host 192.168.247.200
 --More--          deny   tcp host 172.21.62.15 host 192.168.247.200
 --More--          deny   tcp host 172.21.62.25 host 192.168.247.200
 --More--          deny   tcp host 172.21.62.12 any
 --More--          deny   ip host 172.21.62.40 any
 --More--          deny   ip 172.21.62.0 0.0.0.255 host 172.26.2.36
 --More--          deny   ip 10.4.53.0 0.0.0.255 host 172.26.2.36
 --More--          deny   tcp host 172.21.62.29 10.4.54.0 0.0.0.255
 --More--          deny   ip host 172.21.62.25 any
 --More--          deny   ip host 172.21.62.47 any
 --More--          deny   tcp host 10.4.53.44 any
 --More--          deny   tcp host 10.4.53.21 any
 --More--          deny   tcp host 10.4.53.27 any
 --More--          deny   tcp host 172.21.62.29 10.4.53.0 0.0.0.255
 --More--          permit ip any any
 --More--         ip access-list extended BlockBlock
 --More--         ip access-list extended KASEYA_CLASS_OUT
 --More--          permit ip any host 172.24.41.69
 --More--         ip access-list extended SAPP_IN
 --More--          permit ip host 172.26.3.84 any time-range SAPPHIRE
 --More--          permit ip host 172.26.2.36 any time-range SAPPHIRE
 --More--         ip access-list extended SAPP_OUT
 --More--          permit ip any host 172.26.3.84 time-range SAPPHIRE
 --More--          permit ip any host 172.26.2.36 time-range SAPPHIRE
 --More--         ip access-list extended block_out
 --More--         !
 --More--         logging source-interface FastEthernet0/0.99
 --More--         logging 172.24.41.38
 --More--         access-list 67 permit 172.24.41.232
 --More--         access-list 67 permit 172.26.20.53
 --More--         access-list 67 permit 172.26.3.84
 --More--         access-list 67 permit 172.24.41.116
 --More--         access-list 67 deny   any
 --More--         access-list 68 permit 172.26.20.38
 --More--         access-list 68 permit 172.24.41.68
 --More--         access-list 68 deny   any
 --More--         !
 --More--         !
 --More--         !
 --More--         !
 --More--         snmp-server group IIFLNMS v3 auth
 --More--         snmp-server group IIFLNMS v3 priv
 --More--         snmp-server community IIFLNMS RO 68
 --More--         snmp-server community chn2000 RO
 --More--         snmp-server community !75M@I1F7 RO 67
 --More--         snmp-server ifindex persist
 --More--         snmp-server packetsize 512
 --More--         snmp-server trap-timeout 120
 --More--         no snmp-server sparse-tables
 --More--         snmp-server location BM4417+BANGALORE-RICHMOND+Floor
 --More--         snmp-server contact iiflit-network@iifl.com
 --More--         snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
 --More--         snmp-server enable traps config
 --More--         snmp-server host 172.24.41.116 !75M@I1F7
 --More--         snmp-server host 172.24.41.232 !75M@I1F7
 --More--         snmp-server host 172.26.20.53 !75M@I1F7
 --More--         snmp-server host 172.26.3.84 !75M@I1F7
 --More--         snmp-server host 172.24.41.68 IIFLNMS
snmp-server host 172.26.20.38 IIFLNMS
control-plane
privilege ipenacl level 1 deny ip
privilege ipenacl level 1 permit ip
privilege ipsnacl level 1 deny
privilege ipsnacl level 1 permit
privilege router level 2 neighbor
privilege interface level 1 cdp enable
privilege interface level 1 speed
privilege interface level 1 duplex
privilege interface level 1 shutdown
privilege interface level 1 delay
privilege interface level 1 load-interval
privilege interface level 2 ip igmp static-group
 --More--         privilege interface level 2 ip policy
privilege interface level 2 ip multicast boundary
privilege interface level 1 ip pim sparse-dense-mode
privilege interface level 1 ip pim sparse-mode
privilege interface level 1 ip pim dense-mode
privilege interface level 1 ip pim dr-priority
privilege interface level 1 ip flow egress
privilege interface level 1 ip flow ingress
privilege interface level 2 ip access-group
privilege interface level 1 ip address
privilege interface level 1 bandwidth
privilege interface level 1 description
privilege interface level 1 no cdp enable
privilege interface level 1 no speed
privilege interface level 1 no duplex
privilege interface level 1 no shutdown
privilege interface level 1 no delay
privilege interface level 1 no load-interval
 --More--         privilege interface level 2 no ip igmp static-group
privilege interface level 2 no ip policy
privilege interface level 2 no ip multicast boundary
privilege interface level 1 no ip pim sparse-dense-mode
privilege interface level 1 no ip pim sparse-mode
privilege interface level 1 no ip pim dense-mode
privilege interface level 1 no ip pim dr-priority
privilege interface level 1 no ip flow egress
privilege interface level 1 no ip flow ingress
privilege interface level 2 no ip access-group
privilege interface level 1 no ip address
privilege interface level 1 no bandwidth
privilege interface level 1 no description
privilege exec level 1 show ip interface brief
 --More--         banner exec ^CCc -----------------------------------------------------------------------------------------------
                                -----"Warning"-----
This system is for use by authorized users only.
Any individual using this system, with, without, excess authorization acknowledges and consents
to the right of the company to monitor, access,use, and disclose any information generated,
received, or stored on the systems,and waives any right of privacy or expectation of privacy
on the part of the individual in connection with his or her use of this system.
If monitoring / investigation reveals possible conduct of criminal activity, system personnel
may provide the evidence of such activity to law enforcement officers.
Unauthorized and / or improper use of this system, as delineated by corporate policies,
is not tolerated and the company may take formal action against such individuals.
^C
line con 0
 --More--          login local
line aux 0
 exec-timeout 0 1
 no exec
 transport output none
line vty 0 4
 exec-timeout 5 0
 login local
 transport input all
line vty 5 15
 exec-timeout 5 0
 login local
 transport input all
scheduler allocate 20000 1000
ntp access-group peer ntp_server
ntp update-calendar
ntp server 192.168.149.251
ntp server 172.26.20.251
time-range SAPPHIRE
 periodic weekdays 8:00 to 15:30
end
KA-BANGLORE-RICHMOND-BM4417-RT-CIS-TCL#sh ver
Cisco IOS Software, 1841 Software (C1841-ADVENTERPRISEK9-M), Version 15.1(4)M12a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Tue 04-Oct-16 03:13 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
KA-BANGLORE-RICHMOND-BM4417-RT-CIS-TCL uptime is 1 day, 2 hours, 44 minutes
System returned to ROM by reload at 15:23:46 IST Mon Feb 1 2021
System restarted at 15:23:48 IST Mon Feb 1 2021
System image file is "flash:c1841-adventerprisek9-mz.151-4.M12a.bin"
Last reload type: Normal Reload
 --More--
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 1841 (revision 7.0) with 239616K/22528K bytes of memory.
Processor board ID FHK1406723G
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#       PID             SN
 --More--         *0      CISCO1841             FHK1406723G
Georg Pauwen
input/crc errors could indicate a physical (cabling) problem. What is connected to that interface ?
Post the full running configuration of your router. We need to check if something in your configuration (such as access list logging) punts packets to the CPU.
Georg Pauwen
looking at your configuration, it appears that ip accounting and netfow could be the culprits. Do you really need these, and if so, what for ?
Either way, if you don't, remove the lines marked in bold:
version 15.1
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ip bootp server
no ip domain lookup
no ipv6 cef
redundancy
ip ssh version 2
exceed-action drop
class SAPPIRE_OUT
exceed-action drop
violate-action drop
exceed-action drop
class SAPPIRE_IN
exceed-action drop
violate-action drop
exceed-action drop
police cir 3145500
exceed-action drop
violate-action drop
class ASKNIRMAL_IN
police cir 2048000
exceed-action drop
violate-action drop
class class-default
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
load-interval 30
duplex auto
speed auto
no ip redirects
no ip unreachables
no ip proxy-arp
--> ip accounting output-packets
--> ip flow ingress
--> ip flow egress
ip pim sparse-mode
standby 2 preempt
no ip route-cache
no cdp enable
no ip redirects
no ip unreachables
no ip proxy-arp
--> ip flow ingress
--> ip flow egress
ip pim sparse-mode
no ip route-cache
no cdp enable
no ip redirects
no ip unreachables
no ip proxy-arp
--> ip flow ingress
--> ip flow egress
no ip route-cache
no ip redirects
no ip unreachables
no ip proxy-arp
--> ip flow ingress
--> ip flow egress
no ip route-cache
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
no cdp enable
no ip redirects
no ip unreachables
no ip proxy-arp
--> ip flow ingress
--> ip flow egress
standby 71 preempt
no ip route-cache
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
no cdp enable
no ip redirects
no ip unreachables
no ip proxy-arp
--> ip flow ingress
--> ip flow egress
ip pim sparse-mode
standby 99 preempt
no ip route-cache
bandwidth 20480
no ip redirects
no ip unreachables
--> ip flow ingress
--> ip flow egress
ip pim sparse-mode
load-interval 30
speed 100
full-duplex
router bgp 64537
no ip http server
--> ip flow-export source FastEthernet0/1
--> ip flow-export version 9
--> ip flow-export destination 172.24.41.68 2055
--> ip flow-export destination 172.26.20.38 2055
permit 224.5.6.21
permit 172.26.20.38
permit 172.24.41.68
deny any
permit 172.24.41.44
permit 172.24.41.39
deny any
permit 172.26.20.38
permit 172.26.20.46
permit 172.24.41.40
permit 172.26.3.13
permit 172.24.41.39
permit 172.24.41.95
permit 172.24.41.68
permit any
deny any
permit ip any any
permit ip any any
control-plane
line con 0
login local
line aux 0
exec-timeout 0 1
no exec
line vty 0 4
exec-timeout 5 0
login local
transport input all
line vty 5 15
exec-timeout 5 0
login local
transport input all
ntp update-calendar
time-range SAPPHIRE
end
I am concerned about the number of interfaces with no ip route-cache. Are we process switching this traffic?
I am a bit surprised in the output of show process cpu sorted that the first entry was
IP SLAs XOS Even
Rick
"I am concerned about the number of interfaces with no ip route-cache."
BTW, I recall (?) if CEF is active, route-cache has little to no benefit.
