Deploying configuration using Configuration Groups Optional ?
Stevo8300
Frequent Visitor
Frequent Visitor
When deploying SD-WAN configuration using new Configuration Group method. How do you make certain parts optional when deploying configuration.  For example a Static Route / BGP routing to a specific site out of a group of WAN routers on the service side  VPN
I can see it using old method  in feature templates (Mark as optional)  But not in the new Configuration Group method.
If i could kindly get a response to this it would be greatly appreciated.
Many thanks in advance
Hi MHM ,
Many thanks , i get it now 🙂  Traffic Engineering for the Static ,  can also copy configuration groups for example    BranchEdgeServiceSideOSPF  or BranchEdgeServiceSideBGP , then either copy and make a new one as needs be.     Configuration groups used for rapid deployment and to stop template sprawl. Many thanks for you help much appreciated !!
use centralized policy and apply it to site-list include all site ID that you want to apply config
MHM
Hi MHM ,
You are so welcome
MHM
So, you can't make certain options like static routes as optional, right? Just make another CG with new profile for locations that needs static IPs.. and if you have 1 location with 1 static IP and another location with 4 static IP, then it will end up with big amount of CGs eventually, right?
