Different EoS/EoL Dates for Same Device?
pmettewie
Visitor
Researching Eos/EoL dates on different devices on our network and found this information for 2801 routers:
First, these EoS/EoL dates here:
http://www.cisco.com/c/en/us/support/routers/2801-integrated-services-router-isr/model.html
(30-Jan-2013 to 31-Jan-2018)
Then I find these completely different EoS/EoL dates here:
http://www.cisco.com/c/en/us/products/collateral/routers/2800-series-integrated-services-routers-isr/eol_c51-631228.html
(1-Nov-2011 to 31-Oct-2016)
Am I comparing apples to oranges? Is one referencing the first EoS/EoL for any component of a 2801 and the other the chassis? Or something else? Maybe the second URL shown above is for bundles only?
I guess the real question is - when is support for this router ending? October 31st of 2016 or January 31st of 2018?
Paul
Iulian Vaideanu
Level 11
Level 11
How's the first URL related to the 2801 router?  I can only see docs related to the Catalyst 3560-48TS switch...
Iulian,
My apologies ....
I have replaced URL with the correct one - had several screens open and pasted the wrong one.
Paul
I agree that this is confusing. What I believe that I am seeing is that the second URL is about a set of specific products and table 2 shows the specific products to which the earlier date applies and the first URL is more generic about 2800 and applies to 2800 products not included in table 2 of the more specific URL.
So if your specific router(s) match the entries in table 2 of the second URL then the 2016 date applies and if your router(s) do not match anything in table 2 then you probably can use the 2018 date.
Rick
Rick
At the beginning of the EOL FAQ they seem to insist on october 2016:
http://www.cisco.com/c/en/us/products/collateral/routers/1800-series-integrated-services-routers-isr/qa_c67-631674.html
