E1 Controller slip counters error
hiteshoberai
Community Member
We have a 2MB link terminated on a E1 G.703 controller card at both ENd-A & B locations the link has been assigned to a multilink interface at both ends.
Recently we have observed that the slip counters on the controller interface are increasing
this link is taken from an ISP & we have a MUX installed at both ends no modem comes in picture the ISP has tested via loopuk & berth test & say there is no problem from there end.
request you to go through the logs & suggest the cause of the problem with the link or the controller card.
Hitesh
spremkumar
Level 11
Level 11
hi
I would suggestto try out coding the following commands in the global config mode..
network-clock-participate slot0
network-clock-select 1 e1
for more info on the usage tips do check this link out ..
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123tcr/123tvr/vrht_n1.htm#wp1016893
regds
Hi ,
Thanks for replysing i would like to know whether putting this command will reset my controller interface
Hitesh
slanker
Community Member
hi!
you're writeing that you're useing a MUX via a link from an ISP. Are this MUX converting E1 to IP (v.e. RAD IP-Mux)?
Maybe it could be a clocking problem.
Please post a graphic showing your configuration.
