EIGRP error message intermitten
sam-lee
Level 3
Level 3
It seems that error message keeps coming out.Any idea? Attached is the config & error message.Thanks guys!
PTPtr113#
GigabitEthernet0/0 unassigned YES NVRAM up up
GigabitEthernet0/0.1 10.204.176.252 YES NVRAM up up
GigabitEthernet0/0.2 192.168.137.58 YES NVRAM up up
GigabitEthernet0/1 192.168.204.105 YES NVRAM up up
ATM1/0 unassigned YES NVRAM up up
Loopback0 10.1.0.113 YES NVRAM up up
PTPtr113#sh run int GigabitEthernet0/1
Building configuration...
Current configuration : 190 bytes
interface GigabitEthernet0/1
description PTP-SEN-Global - 34Mbps
bandwidth 29500
ip address 192.168.204.105 255.255.255.252
delay 200000
duplex auto
speed auto
media-type rj45
end
sentr102#
GigabitEthernet0/0.1 10.204.16.7 YES NVRAM up up
GigabitEthernet0/0.2 unassigned YES unset administratively down down
GigabitEthernet0/1 192.168.204.106 YES NVRAM up up
Loopback0 10.1.0.111 YES NVRAM up up
sentr102#sh run int GigabitEthernet0/1
description SEN-PTP-GLobal - 34Mbps
bandwidth 29500
ip address 192.168.204.106 255.255.255.252
delay 200000
duplex auto
speed auto
media-type rj45
end
sentr102#sh log | i GigabitEthernet0/1
Sep 10 11:45:56.564 UTC: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor
192.168.204.105 (GigabitEthernet0/1) is up: new adjacency Sep 10 21:26:37.413 UTC: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor
192.168.204.105 (GigabitEthernet0/1) is down: holding time expired Sep 10 21:27:00.093 UTC: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor
192.168.204.105 (GigabitEthernet0/1) is up: new adjacency Sep 11 03:52:16.384 UTC: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor
192.168.204.105 (GigabitEthernet0/1) is down: holding time expired Sep 11 09:44:17.577 UTC: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor
6 Replies 6
CriscoSystems
Level 8
Level 8
Can you show us the output of "show ip eigrp interfaces" ?
What are the hello intervals configured on each interface?
as suggested look at your EIGRP timers. also i noticed you have duplex, speed set to AUTO on your interfaces!! best to set speed and duplex manually?
Sam Lee
Without knowing a bit more about the topology of the network, it is difficult to say exactly what is going on. The error message that holding time expired is an indication that your router has sent EIGRP traffic to the neighbor (probably EIGRP HELLO messages) and has not received a response and so will terminate the neighbor relationship and wait till it has received a HELLO from the neighbor before it rebuilds the neighbor relationship.
Looking at the messages and their timestamps we can see that there is this sequence:
- 11:45:56 neighbor is up
- 21:26:37 neighbor is down (so it was up for 9 hours and 40 minutes)
- 21:27:00 neighbor is up (so it was down for 23 seconds)
- 3:52:16 neighbor is down (so it was up for 6 hours 25 minutes)
- 9:44:17 neighbor is up (so it was down for 5 hours 52 minutes)
So one of the incidents was very short and one was not. Without more information it is difficult to figure out what is going on. What is the connection to this neighbor? Are there signs of similar issues on the neighbor? Are there signs that there was any problem in the connection between the neighbors (especially in the problem that lasted over 5 hours)?
[edit] and unless there is a particular reason to hard code speed and duplex I believe that with todays equipment it is usually better to set speed and duples as auto.
Rick
Rick
Rick...I thought hello's were unacknowledged in EIGRP? What sort of response to a hello packet are we talking about here...
Perhaps "response" was not the optimum choice of words. In establishing the EIGRP neighbor relationship the routers establish a time interval in which they need to hear EIGRP protocol traffic from the neighbor (typically HELLO messages) and they use the holding timer to track this. If the holding timer expires before the router receives EIGRP protocol traffic then it terminates the neighbor relationship.
Rick
Rick
Giuseppe Larosa
Hello Sam,
EIGRP timers can be different for each neighbor in a link they don't need to match.
I would focus on another aspect:
the lack of QoS configuration.
your interface has the following description
this makes me think you are using some WAN service or EoMPLS service that is limited to 34 Mbps.
you should on both sides do the following:
shape outbound at 33000 kbps
eventually depending on platform you may need to protect EIGRP packets using a CBWFQ.
a)
police shape-all-33Mbps
class class-default
shape average 33000000
service q-eigrp
access-list 111 permit eigrp any any
class-map eigrp_traffic
match access-group 111
policy-map q-eigrp
class eigrp_traffic
bandwith 500
class class-default
fair-queue
int g0/1
service-policy out shape-all-33Mbps
do this on both ends because the problem can be on the other side.
Hope to help
Giuseppe
Edit:
Rick is on a better path:
5 hours of neighbor down cannot be explained without an out of service of provider or remote device.
