eigrp issues
muskap
Community Member
Im trying to connect all three routers using eigrp however it doesnt seem to connect. The file attached is the network and is after i tried adding eigrp to all three routers but failed and removed the protocols. Can anyone try to help? Ive been stuck with this for a couple of days and cant seem to figure out what im doing wrong.
Commands i used on all routers:
router eigrp 100
network 192.168.59.0
also tried network 192.168.59.0 255.255.255.0
Looks like you might be running an older version of PT. I cant open the file. Can you provide a diagram and what you have the interface IPs set to for each router and their connections to each other. This looks like a similar issue posed earlier. If all 3 of your routers connect to each other they cannot all use the 192.168.59.0/24 subnet. It needs to be subnetted out so they are all using their own unique subnet.
-David
router 1-2 is using 192.168.59.200/30
router 1-3 is using 192.168.59.204/30
router 2-3 is using 192.168.59.208/30
Make sure each interface is in up/up status.
Make sure each router can ping its directly connected neighbor IP address.
Then try this:
router eigrp 100
network 192.168.59.0 0.0.0.255
no auto-summary
