eigrp unequal load balancing problem
gchiarelli
Community Member
hell0: I have a hub and spoke topology, with 10 spokes, each spoke has two links to the hub, they are hdlc links, one of 1mb , and the other 256k, all spokes are conecting the same way, the problem is that I can not get unequal load balancing for each spoke, I have configured variance, maximun-paths, but nothing happens, any idea, any could help me?
thanks
Gustavo
francisco-vazquez
Community Member
Can you send your Hub config?
I assume you have unde iegrp process
variance 4 and traffic-share balance commands (the last one won´t be seen in the config)
Fco Vzqz
I don't have the configs right now, but I tested the configuration changing variance(up to 128) and maximun-path( up to 16), but nothing happened.
perhaps i have some problem with feasible successors
ruwhite
Level 11
Level 11
What are the metric (FD) and the reported metric (RD) for each of the routes? EIGRP won't unequal cost load share over links that are not feasible sucessors. If you post a show ip eigrp topo for one of the specific routes from one router, we could take a look, and see.
Russ.W
