10-08-2025 07:53 AM
Is it possible to enable IPS (or at least IDS) on a Meraki MX105 running firmware MX 18.211.6 to inspect all unencrypted traffic for ransomware, malware, and virus signatures, and block anything nefarious? Or can we have an easily applied policy not a substitute for endpoint solutions, just to maximize network protection. I can't see this configuration option in my MX (Security & SD-WAN > Configure > Threat protection > Intrusion detection and prevention.)
Solved! Go to Solution.
10-08-2025 08:16 AM
Are you using enterprise or advanced licensing?
10-08-2025 08:16 AM
10-08-2025 08:28 AM
Enterprise licensing, so this option would not be available in this? we would need advanced licensing. Thank for clarification.
10-08-2025 08:33 AM
The advanced security license and Secure SD-WAN+ will allow IDS/IPS (yes) whereas it's not an option with the enterprise license.
10-08-2025 11:29 AM
Content Filtering is quite effective at blocking access to content *prior* to it being downloaded - but you need an "Advanced Security" licence.
These are the categories I like to use.
ps. I chose everything under "Threat Categories".
